Procedure debate
See what written?? That when you accept a new clearance you are no longer on your old clearance?
Well, not exactly true. With "Pilot's Discretion" you are cleared to fly the new clearance when ever you like. You are still cleared to fly at your current altitude, you are also cleared to fly at any altitude between your present altitude and the assigned altitude.
Do you have to report leaving the altitude? Yes. In fact, you are supposed to report leaving an altitude on any altitude change (while not on an approach). I don't personally do it because it seems to me that if you accept the clearance the logical conclusion is that you are vacating your previous altitude, but I have heard plenty of pilots make the report.
As for finding it in the FARs, you won't. Here's why. They don't create a regulation for every procedural aspect of flight. There's no regulation that says you have to put the gear down...is there? No. Some of that stuff just has to be assumed and if you do do something stupid like leaving the gear up on landing, they've always got the catch all 91.13 Careless and Reckless Operation.
Back to "Pilot's Discretion" for a moment. Reporting leaving your first altitude is required. Also, should you level off at some altitude in between, reporting leaving that altitude is required as well. It is in the AIM, it is required and it can be a violation (though probably won't be unless you cause a serious problem and the FAA has nothing else on you).
Originally Posted by GravityHater
BUT some say the FAA has busted people for what IS in the AIM
I'm going to have to throw the BS card down on this one man.
I'm going to have to trump your BS card with my BS flag. The FAA can and has indeed violated pilots for not following the AIM. The reg is 91.13, Careless and reckless operation. This one covers most of what is not actually written. Also, what if a pilot is involved in a civil suit and the case was related to a pilot not following the "recommendations", in the AIM? Do you think that the defendant would win the judge's heart because he testifies, "uh, well, I figured that the AIM is not regulatory"?
I'm not saying that one would get violated for not giving a courtesy call that you're vacating an altitude. However, GravityHater's point stands.
When a controler gives you a PD clearance and you accept it, at that time you've accepted the entire clearance limit for that block altitude. Also, by accepting the PD clearance you have vacated the previosly assigned altitude. You are no longer flying at that assigned altitude and are now opperating in the block altitude.
That's not true and it doesn't even make sense.You have not vacated a previously assigned altitude until the airplane physically leaves that altitude.
I should have added the word 'clearance' to the end of that sentence. "by accepting the PD clearance you have vacated the previously assigned altitude clearance."
Where in the AIM does it say that you should report leaving every altitude you level off at?? You just made that up!
Acknowledging a PD clearance is not the same as vacating the altitude. This comes up every once in a while, and the pilot community is split on either side of the issued. The thread will go 5 or 6 pages and neither group will convince the other.
BTW, I think it is a required call, but that's just me.
Agreed. Luckily for me, it's in my ops manual, nice and neat, that I have to report vacating. Problem solved. :)
Think about it from an operational perspective. You're level at FL350 with discretion to FL230. ATC cannot assign another aircraft FL350 or below that would cause a loss of separation with your aircraft. You begin your descent and notify ATC. They now know FL350 is available for other aircraft in the vicinity, and it's for this reason you cannot return to FL350 whether you reported leaving it or not. By making it a pilot initiated call ATC does not have to constantly monitor an aircraft with a discretionary climb/descent to figure out when they have started it, thus relieving their workload. At least that's what I believe the intention is, whether or not it works that way in the real world I have no idea.
As far as it being regulatory I would argue no, in that if there was a fed on the jumpseat and you failed to report leaving an altitude would you expect a violation? I wouldn't. OTOH though, if you didn't and a loss of separation resulted that would have been noticed had you made the report I would expect an investigation even if the error was made by ATC.
Short of getting a Chief Counsel interpretation letter with a definitive answer, the OP and his colleague could always just buy each other a beer...
Not required. By getting PD the airspace is totally clear from your current altitude down to where they cleared you to go in the PD clearance. Like getting a block altitude to cruise in. If you wait too long to descend and traffic is getting closer ATC will call you and tell you to start down or cancel your PD clearance.
But you know how the FAA is......if a problem ever occurs in your PD descent and there's a traffic issue and you didn't call "leaving XXX altitude" they will use that to burn your azz. So just do it everytime.
People who say the AIM is not regulatory, are like the people who say they don't have to pay income taxes because its not in the constitution. They get away with it for a while, but sooner or later they get busted.
The requirement is to make a report when vacating an altitude. If you occupy an altitude for a significant amount of time, you are required to vacate it.
No, the requirement is to make a report when vacating an assigned altitude, and once again after accepting a PD clearance, you are no longer flying at an assigned altitude. Your new assigned altitude is the one the controller cleared you to descend to at your discretion.
Here's the thing, people are creatures of habit. If making a vacating call after receiving a PD clearance is what you've been doing your whole flying career and it gives you the 'warm and fuzzies', then by all means do it. It doesn't cost any extra. But this by no means makes it a 'requirement', which is what the OP was asking about.
Ok, I can buy that you don't have to make the call at an intermediate altitude on a PD. However, when you are assigned a PD you are still assigned the current altitude. If not, you could not remain there. In any event, at some point you were assigned that altitude so even if the clearance is "descend and maintain...." you are still required to reply "leaving XX, descending XX...." or "vacating xx."
No sir, you are not! Think about it, how can a controller logistically give you two assigned altitudes?
Why not? It's no different than every other intermediate altitude that you're allowed to level off and remain at.
So when do you need to report leaving an altitude?
Nope. If that were true, this requirement would be totally worthless as it would be impossible to vacate the currently assigned altitude (because it's always a different altitude from the altitude currently being flown and you haven't gotten there yet).
If at FL410 with PD to FL350, FL350 becomes the newly assigned altitude, and FL410 is the previously assigned altitude, but it was an assigned altitude nonetheless and it should be reported when vacated.
Like many other procedures in the AIM, it probably was written to be used non-radar, but it is in there, so it is required.
I'm no FAR whiz but you keep spouting off on this thread using the word required.
Yet at no time throughout this thread have you cited any reference for this requirement.
I'm not saying that you're wrong (although I disagree with your argument). But I am concerned that in your position as a Chief Pilot you have the opportunity to educate and mold the present and next generation of professional pilots, however it appears that you may be doing more
proselytizing than educating with references and facts.
Like I said earlier, I usually report leaving an altitude after being given a PD clearance but I never felt the need to and I've never seen a reg. or reference to one that requires me to do so.
Prove it to me, I'm always willing to learn something new.
In this exact situation I had a controller chew me out for not telling him. I apologized and figured it was just my lack of knowledge on the regs. I later called a center manager and asked for his take on the situation. He indicated that it was a helpful courtesy but probably a bit of a gray area.
I'm not saying that you're wrong (although I disagree with your argument). But I am concerned that in your position as a Chief Pilot you have the opportunity to educate and mold the present and next generation of professional pilots, however it appears that you may be doing more proselytizing than educating with references and facts.
First off, why repost something that is already in the thread? Several people posted the AIM sections that cover this. As for being required and being a regulation, there is a difference. A concept a lot of people don't seem to grasp. The regulations don't post every single requirement. Some required procedures are in the AIM. Try not reading back a hold short. You won't find it in the FARs, but you damn well better do it. There is also nothing about using the phonetic alphabet. Nor is there anything that says you can't key your mic and hold it.
You are required to make the a call when vacating a previously assigned altitude. It is in the AIM....Chapter 4.
This is the first time in this thread that you've contextually used the word 'required' correctly as it pertains to vacating an altitude.
Still, it logically seems to me that this requirement is met when accepting your DP clearance and therefor redundant to call again.
I tell you what, the next time that you accept a PD clearance, acknowledge it by saying "vacating xxx for xxx at our discretion".
Problem solved! ;)
Problem solved! ;)
Well, there is your problem right there. You are trying to apply logic to the FAA. :D
I am sorry that I didn't put together a proper collegiate level thesis on an anonymous internet forum for you. I wasn't aware that I would be graded on context, grammar and spelling. Fortunately my spelling and punctuation errors didn't fall to a level that caught your attention.
Is it redundant to announce your departure from an altitude after accepting a PD? Sure. But it is also required. How many other redundant procedures do we have? Checklists maybe?
Just because it is redundant doesn't mean it isn't required.
Have any of you ever thought to ask a controller? They are the reasons we do all these things anyway right? So THEY don't tell someone about US? So just ask a few and see if the debate continues... then again i was in a tower once and saw a target overhead the class C with no alt readout and i asked "isnt he supposed to have mode C?" and the controller said "i dont think so, why?" so maybe they dont even know......
I know this is a serious topic since it involves an adult beverage going to the victor.
All of you have come up with some good points.
I feel the best general practice for day to day use when it comes to PD clearances is to cover your butt. (Tell ATC you are descending whether it is busy or not busy on the frequency) I sometimes ask myself to think what it would be like explaining to an FAA official after I have been red flagged for anything I did to MAYBE cause that situation. If I cover my bases such as including the call out that I am leaving an altitude on a PD clearance then I will feel better about it after it is communicated.
By the look of this thread it is hard to definitely pick a winner. Grey area is correct.
I hear all the aurguments..but has anyone ever asked the controllers..I have asked many of my friends who are controllers at large centers and approach controls. They all said the same thing to me. "If I wanted you to make another radio call I would not have given you a PD clearence."
End of story for me!!
Again I ask you, prove your claim that it is required. I'm not saying that you're wrong (although I disagree with you) but if you are going to take such a staunch (sp?) position, prove it to me. I'll be happy to come over to your side of the fence with proper documentation.
http://www.faa.gov/air_traffic/publications/atpubs/aim/Chap5/aim0503.html
5-3-3. Additional Reports
a. The following reports should be made to ATC or FSS facilities without a specific ATC request:
1. At all times.
(a) When vacating any previously assigned altitude or flight level for a newly assigned altitude or flight level.
(b) When an altitude change will be made if operating on a clearance specifying VFR-on-top.
(c) When unable to climb/descend at a rate of a least 500 feet per minute.
(d) When approach has been missed. (Request clearance for specific action; i.e., to alternative airport, another approach, etc.)
(e) Change in the average true airspeed (at cruising altitude) when it varies by 5 percent or 10 knots (whichever is greater) from that filed in the flight plan.
(f) The time and altitude or flight level upon reaching a holding fix or point to which cleared.
(g) When leaving any assigned holding fix or point.
Not to take this to another level but what about international, do you make a level off call?
Ex London Control tells you to descend to FL210, do you call, "level 210" upon reaching FL210?
Pardon my laziness for not reading the entire thread.
Depending on how long until start down it is not a bad idea to call vacating you altitude. For the simple fact that the control may have forgotten he gave it to you and accidentally vectored someone underneath you.
It is mentioned in the AIM several times for many reasons, but let's all remember the AIM is not regulatory.
So, it is not regulatory but in some situations it can be considered a good operating procedure and a courtesy.
You're owed a beer
[SIZE=+1][/SIZE]​
Chapter 5. Air Traffic Procedures
[SIZE=+1] Section 3. En Route Procedures[/SIZE]
5-3-3. Additional Reports ​
1. At all times.
Main Entry: pro·ce·dure
Pronunciation: \prə-ˈsē-jər\
Function: noun
Etymology: French procédure, from Middle French, from proceder
Date: circa 1611
1 a : a particular way of accomplishing something or of acting b : a step in a procedure
2 a : a series of steps followed in a regular definite order <legal procedure> <a surgical procedure> b : a set of instructions for a computer that has a name by which it can be called into action
3 a : a traditional or established way of doing things
Main Entry: should
Pronunciation: \shəd, ˈshu̇d\
Function: verbal auxiliary
Etymology: Middle English sholde, from Old English sceolde owed, was obliged to, ought to
Date: before 12th century
past of shall 1 —used in auxiliary function to express condition <if he should leave his father, his father would die — Gen 44:22(Revised Standard Version)>
2 —used in auxiliary function to express obligation, propriety, or expediency <'tis commanded I should do so — Shakespeare> <this is as it should be — H. L. Savage> <you should brush your teeth after each meal>
3 —used in auxiliary function to express futurity from a point of view in the past <realized that she should have to do most of her farm work before sunrise — Ellen Glasgow>
4 —used in auxiliary function to express what is probable or expected
