Plane crash in Kentucky???
Here's a good example of someone who is completely dependent on sophisticated navigation flying right into the side of a mountain .
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20021106X05441&key=1
He was counting on the magic to tell him if it was safe, and it didn't give him enough warning. Exactly why it let him down is a subject of discussion, but the bottom line is, it did let him dowm.
Now, if he had pulled out a sectional, and taken a look at the terrain, he would have seen that a direct turn toward Bethel puts you right into a ridgeline, but he just blasted off and trusted that the display would make up for his lack of situational awareness. Didn't work very well for him.
mtrv said:
Besides, I don't know what's worse; glass panel pilots not being proficient at old school navigation; or the old school boys and girls not having a clue how to operate glass, and won't dare admit it. I think we're somewhere in the middle of all this, right now.
I think it should be obvious to anyone with a modicum of sense thet a glass dependent pilot who has never flown traditionally and is completely reliant on his glass to get him through the sky is much much worse than someone who is adept at establishing good situational awarenesss through traditional means but who has never worked with glass.
One of the aircraft my company operates is a (realatively) modern glass cockpit aircraft. I've jumpseated a couple of times and it's not rocket sience, in fact it's pretty simple. sure I don't know which buttons to push to make it do what I want, but that's just system specific training, as far as looking at it and knowing where I am, it's not tough. I doubt that someone who had learned to fly with all that help could step into my round dial cockpit and figure our where they were based on the raw data.
It's the difference between not having been trained on a specific system, and lacking fundamental skill essential to aviation.
There's a world of difference, and if you're unsure which is worse, you have a lot to learn.
Again, I want to reiterate that I am not putting down the technology. I am however, putting down the notion that you keep bleating, that we should skip learning basic airmanship because there are machines that can do it for us.
It's like insiting that we should drop basic arithmentic from elememtary education because we have reliable calculators now.
mtrv said:
And, why would you say that? Perhaps if it's one of those old school low resolution, narrow field of view GPS's that draw a line on an empty background, then it's possible.
However, with today's terrain depicting, visual terrain warning, and audio terrain warning GPS's in high resolution color, the chances are most likely a lot less. And with 3D virtual terrain presentations, the chances will drop even farther.
Just think, someday, even the modern airliner cockpit might have uplinked XM Satellite type weather, dipicting weather for hundreds of miles, instead of the limitations imposed by radar.
I know of several airline pilots who are jealous right now; and I know many retired commercial and military pilots who would no longer care to fly long cross country flights without XM weather. We're all in that older age, high performance experimental/homebuilt crowd.
Yep, once they've seen it, and used it, they certainly know the value. This is fact! I'm also surprised by how many high tech glass panels go into these kitbuilt airplanes. But if you have money, and the interest to learn how to use them, then why not?
A statistic waiting to happen.
What do you do when your precious moving map fails?
Since you have no practice with situational awareness using
normal instruments, you hit a mountain.
CE
CE
Since you've been following along with a sectional in hand, on the seat, knee board, whatever; you know exactly where you are, the second the GPS fails. Then just make sure your backup GPS is still right on target. You DO have a backup, as well as extra batteries, and a hand-held transceiver, don't you?
Of course, using high failure rates in GPS's as an excuse to not use them is pure fiction. The chances of an out of service navaid are greater, except for NOTAM areas where it's stated that the GPS may become inaccurate.
I suppose I'll just have to start a set of links to all those flight into terrain accidents, where situational awarness was lost, and no high res GPS with terrain features was on board. The listings go on and on and on. Yes, awarness could have been regained in a second, but not when a GPS unit isn't to be seen. A good moving map display on an MFD would probably prevent loss of awarness, even when you didn't realize it was lost.
Maybe I'll just start the links with Frank Sinatra's mother's aircraft, that hit a mountain around 50 years ago. These pilot's didn't realize they were lost either! Then there is Reba's band, the Ron Brown 737, the AA 757, and, and
Good luck...
CE
Runway 26 unlighted, apparently.
The RJ is glass, isn't it? I don't really think this is a glass panel issue, or even a GPS issue. The practice of setting one's heading bug to runway heading, a standard pre-takeoff practice at some operations, comes to mind. There are heading bugs on full glass panels, too. Whatever your thoughts about glass, GPS, etc., there will probably be more attention paid now to heading indicators/bugs on line-up.
Of course, we don't know all the facts.
RIP.
I now only fly out of a hand full of airports, most are the simplified layouts as in the new Hong Kong airport with a four parallel runways, terminal in the middle, how many little fields do the RJ's drivers have to be familiar with, new taxi procedures within the last week, very early morning and a complicated airport layout, tough conditions for anyone.
There is a special advanced piece of equipment in my airplane that helps prevent departure on the wrong runway.
It's called a compass.
CE
What about last week when the entire south east was NOTAM'd as unreliable GPS coverage? I have yet to see an entire region of VOR's drop offline.
Learn the basic six...F*uck the new Sh*t. When you can fly a partial panel NDB approach in turbulence with an engine out, then you can move up to a GPS. Uh....you might want to try that in a twin.
I'm really going to miss NDB's, they are the best navaid out there.
CE
Yeah, they had one. But.......something happened that led to these guys missing that check. Certainly they'd been in similar situations dozens, if not hundreds of times.
We've all been in a 'spot' where we, or the other pilot, or controller, or wingman caught something that would've made a HUGE difference.
I've lost too many friends and acquaintances in crashes, that were good pilots, for me to ever think 'it can't happen to me'.
What sequence of events, or comm error, or cockpit distraction, or other factors, etc led these 2 to roll down Rwy 26? That is what we need to know.
Fugawe
Fugawe
I suppose I came across a bit harsh. i meant mistakes can happen even with the best glass suite. I've made mistakes too, a few involving distraction.
CE
I was in LEX little more than a week before the accident. I managed to taxi to the runway, single pilot while copying my clearance and completing checklists in my 15th hour of duty and 7th hour of flight time. That is no joke either nor is it an exageration. When I came to 26, there was a big red sign saying 26. I passed that, took off on 22 and went on my merry way. It was not confusing and it was my first time there in 3 years or more.
I don't say all that to point out how cool I am cause I did it with out a problem. I made that statement to illustrate that the taxi route was not complicated and that making excuses for them is not going to do anyone any good. They screwed up PERIOD. There is no excuse, no reason, no logical explination that is more fitting. And there is no technollogy that would have saved them. The lights where off on that runway, yet they didn't question tower. The heading was obviously wrong, yet they ignored that. The signage was clearly visible, yet they some how missed that. They ignored or missed many warning signs and one more sign probably would not have changed the outcome. They had their heads shoved so far up where the sun don't shine that you could have dropped a nuke on the other end of the runway and they would have still departed.
Are you mad that I said that? Good, use that anger to make sure you don't become these guys. Be motivated by the fact that if you screw up some arm chair pilot like me will be out there telling people you screwed up.
I'm sure they where good people that just did the wrong thing at the wrong time. However, no matter how good of a pilot or person they where, the truth has to be recognized so that every one else will learn from it. I don't mean to be harsh, but we can't make excuses for them. That just does not serve aviation well.
mtrv said:
Yes, I'm quite pissed at everyone who believes that GPS techology should come in second place to old school. I see it all the time here.
GPS is great when it works correctly.
That is not always the case though. I have had several times when a GPS system failed or lost its bearings in the middle of an approach. Not talking about the cheaper G/A stuff either. Air carrier quality FMS based systems that just "forget" where they are from time to time.
Additionally GPS and FMS systems can actually be a hinderance in some cases, NY airspace comes to mind, 5 route changes in 15 minutes in heavy weather etc....several times I have "abandoned" the new glass stuff for a bit in favor of the quicker to tune and change vor to meet ATC's changing needs. The last thing you need is your head down trying to figure out how to spell some fix or typing instead of flying. If we always got to fly what our clearance says the GPS would be perfect....
No navigation system is perfect, anybody that relies 100% on any one system will eventually end up dead, it is just a matter of time. Situational awareness is gained through the use of all availiable means. Glass is great, but it is not the holy grail of navigation, just like any other system it has it's own quirks that can get you if you do not keep it honest with other systems.
I've found that many retired high hour commercial pilots that I know, or am aware of through internet forums, seem to have quite an interest in the new stuff, and much less with the old. Maybe it's a "been there, done that" mentality. I don't know, and it's just an observation.
Much has to do with experimental/homebuilt/kitplanes, such as Lancairs, RV's, Rockets, F1's, etc.. Some of these people put a lot of dollar$ into their panels.
Six pac steam gauge panels are constantly being replaced with high tech glass setups, along with solid state A/P's.
Like I said, just an observation, but it's true, never the less.
