Typhoon1244
Member in Good Standing
- Jul 29, 2002
No, because if you're holding pitch (for whatever strange reason) then it's not variable.Mickey said:So if we hold pitch and reduce power we can maintain altitude but not airspeed...
CRJ. Not sure where you got J41 from...Mickey said:So you are flying your CRJ or J41 (which is it?)...
First, I'd increase the rate of descent by increasing the pitch attitude slightly, referencing the VSI...because pitch controlls altitude/rate-of-descent. Then I'd see what effect the change had on airspeed. There will be an increase. If I'm satisfied with the increase, I'll leave the power alone. If it's not enough, I'll add power. If it's too much and we're flirting with the barber pole, I'll decrease power...because power controls airspeed if both pitch and power are available and variable....and you start a descent for ATC. ATC tells you to increase your descent rate and increase your speed. Do you add power and lower your pitch? I think reducing your power and lowering your pitch will work.
Tell an F-15 driver that!Timebuilder said:After all is said and done, pitch has the last word on airspeed, and power has the last word on altitude.
Well according to some, all he has to do is push the stick and he'll shoot forward like a bat out of hell.Timebuilder said:Tell an F-15 driver he has no power. Now, order him to take off. How high will he climb?
Typhoon1244 said:Well according to some, all he has to do is push the stick and he'll shoot forward like a bat out of hell.
You didn't answer my autopilot question. How does yours work?
Sit in the runway with the power at idle, pull back on the yoke and see how long it takes for you to get in the air!"
Typhoon1244 said:Next time I'm skimming into DFW at FL240 and 330 knots, and Center asks me to slow to 250 for spacing, I'll leave the power in and pull the nose up fifteen or twenty degrees since, you know, pitch controls airspeed.
