Pilatus PC12 vs. King Air200
  • Thread starter Thread starter JimG
  • Watchers Watchers 14
irapilot said:
My question whenever someone selling or talking up the PC-12 and they mention the glide ratio is "that's great in most conditions but let's say you are flying over rugged terrain with clouds right down on the deck and although you took off VFR and your destination is VFR, what happens when the engine quits now, or the prop fails (the awesome glide ratio is predicated on the prop being in feather), with VFR conditions out of glide range, what do you do then?" I never have gotten a good answer that makes me feel warm and fuzzy about that situation.
Been gone a few days and just now stumbled upon this. What I'd do in the above scenario is establish min sink speed which is I'm sure significantly slower than best glide and then after you've tried to relight I'd ask ATC to vector me to known suitable terrian (maybe a river, lake, stream or large road.) I believe ATC has an emergency video map which shows the terrain and other features in great detail overlaid from the radar screen. ATC also I believe has an emergency MVA and MSA or like that which of course is lower than the normal MSA/MVA. After praying to whatever higher power you believe in my #1 priority would be to maintain a minimum forward and vertical speed and try to get an idea from local atis or awos the winds keeping in mind it might vary tremendously over just a few mi in the mtns. I'd rather make a controlled crash into whatever at 5-10kts above stall that lose control from stalling and almost certainly be killed that way!
Just so there's no mis-understandings, you're somewhat correct. We have an EOVM map we can call up in terminal facilities. Centers don't have them. Not all App controls have them, but many do. Note that there's no way to map out every cotton-pickin' cell tower out there, just the higher towers. The requirements for an EOVM map are as follows:
Order 7210.3T
Facility Operation and Administration
3-9-4. EMERGENCY OBSTRUCTION VIDEO MAP (EOVM)
a. An EOVM shall be established at all terminal radar facilities that have radar coverage in designated mountainous areas and an available channel in their video mappers. This map is intended to facilitate advisory service to an aircraft in an emergency situation wherein an appropriate terrain/obstacle clearance minimum altitude cannot be maintained. (See FIG 3-9-2.)
NOTE-
1. Designated mountainous areas are identified in 14 CFR Part 95, Subpart B.
2. Appropriate terrain/obstacle clearance minimum altitudes may be defined as MIA, MEA, Minimum Obstruction Clearance Altitude (MOCA), or MVA.
b. Alternatives, such as combining existing maps, eliminating a lower priority map or, as a least desirable alternative, merging the EOVM with the MVA map, shall be considered when necessary to accommodate the EOVM.
c. EOVM Use: The EOVM shall be used and the advisory service provided only when a pilot has declared an emergency or a controller determines that an emergency condition exists or is imminent because of the inability of an aircraft to maintain the appropriate terrain/obstacle clearance minimum altitude/s.
d. EOVM Design:
1. The basic design of the EOVM shall incorporate the following minimum features:
(a) Base contour lines of the mountains with the highest peak elevation of each depicted mountain plus 200 feet for natural low obstacle growth.
(b) Highest elevations of adjacent topography; e.g., valleys, canyons, plateaus, flatland, etc., plus 200 feet, or water.
(c) Prominent man-made obstacles; e.g., antennas, power plant chimneys, tall towers, etc., and their elevations.
(d) Satellite airports and other airports which could serve in an emergency.
(e) MVA if the EOVM must be merged with the MVA map for the former to be accommodated.
(f) Other information deemed essential by the facility.
NOTE-
To avoid clutter and facilitate maintenance, information depicted on the EOVM should be restricted to only that which is absolutely essential.
2. All elevations identified on the EOVM shall be rounded up to the next 100-foot increment and expressed as MSL altitudes.
NOTE-
To avoid unnecessary map clutter, the last two digits are not required.
EXAMPLE-
2=200, 57=5700, 90=9000, 132=13200
e. EOVM Production: The preparation and procurement of the EOVM shall be accomplished in accordance with FAAO 7910.1, Aeronautical Video Map Program.
f. EOVM Verification: The original EOVM procurement package and any sub- sequent changes shall be checked for adequacy and then coordinated with the appropriate FIAO to verify the accuracy of its information. Annually, the EOVM shall be reviewed for adequacy and recoordinated with the FIAO for accuracy.
We fly our PC-12's in hard IFR all the time. I am very confident in the PT-6. I think our company is at 35,000+ hr. in the aircraft. We have not had any problems yet. 140kt at the marker w/ an engine loss and you will make the runway. At altutide it will glide 78nm. If you can't find somewhere to put it in that kind of range your in the wrong biz.
With all due respect, I believe you will be able to better answer this when you have 2,000+ hours of multi-engine time. Perhaps you simply do not know any different right now, and that's fine. If you're flying overwater, no matter what your glide distance is if you're far out over the ocean you're going to land in the water. And remember, NO WIND the glide distance is 78 nm. A 100 knot headwind is not unheard of at 27,000 feet. Your 78 nm number just went down the toilet. You can say you'd make a 180 degree turn and take advantage of the tailwind. Fine, but what will that turn do to your glide distance? Think of the loss of lift as you make the 180.
All I am saying here is remember one engine is one engine. You may have 35,000 hours on the PT-6 at your company but one engine fails (and as you are aware, it HAS happened in the PC-12 series aircraft), and it could get ugly...
Jeff
I used to fly the PC-12 before I moved to the BE-1900. At the time the single engine thing did not bother me. But as reliable as the PT6 is, they do fail, I watched a 1900 land single engine in Boston yesterday.
I have never done a V1 cut in the airplane, but in the sim they are a piece of cake. Folks who have done them in the airplane say they are even easier. I would imagine the King Air 200 is not all that different.
Don't get me wrong, I like the PC-12. It is a remarkable aircraft. But I think my minumums would be much different flying it now than they were a few years ago.
BTW, I did see 271 TAS in the PC-12 once at FL 240.
Having flown both, I would say that they are both incredible aircraft. I currently fly the PC-12 only, so my opinion is slightly biased. Like my Alpha brotha above me, I feel that single engine IMC in the Pilatus is not that big of a deal. Between having 2 pilots and some of the best avionics money can buy, the outcome will be a good one. Yes, you will be meeting mother earth when the engine quits in the Pilatus. That is what training is for. We constantly train for engine out after takoff and the standard breif prior to departure is that we are coming back to the airport at 800 AGL, otherwise straight ahead, while trying to avoid obstacles. At 65-70kts and 23G seats, you should walk away. There are 550 PC-12s out there, and only one fatal accident that we don't know the cause of, the PA accident. The FCU issue should hopefully be solved with the modification, and all of ours have it done, thankfully. This is a great airplane for traveling and lots of folks like the economy of them, along side the comfort factor. Many more will be sold with these crazy fuel prices. Now if Pilatus could only manufacture more per year......................
I'm flying on one as a passenger monday from Anchorage to Iliamna for a fishing trip. I think being on that crew might be my dream job.
Get to know the owner really well and your opinion might change.
Jeff
I don't do AR's. And I especially don’t do them now that I have been thru
<a href="http://www.survivalsystemsinc.com/ged.htm"Survival Systems>
training. Makes you think.
Well it comes down to apples and oranges, but if you like the PC12 then you like it....Harrison Ford dumped hid KA and is now a 12 guy....and he loves the range of missions that the airplane is capable of. with that said beech has sold a hell of a lot of KA's and are still doing so...so why cant we all just get along?LOL
VISIT www.redcross.org lets help OUR people
Jeff
With all due respect...I don't do AR's. I especially don’t do them now that I have been thru Survival Systems training. Makes you think. I'll trade the one min. turn for a 100kt. tailwind. My logic is the if the engine goes, I'll deal with it. If the wing falls off, I'll deal with it. There are critical time were if something goes wrong we are all screwed, one engein, eight engines, whatever. I believe in the airframe and engine. Our maintenance department and our pilots are on the ball. We understand the risk.
The responses in this thread are very segregated. Newbies with PC-12 enthusiasm, and the wise old pelicans who know better. Wisdom is being dispensed, don't pass it up.
Can't wait until the VLJ's hit the market, this board is going to be a riot:)
Hey, if you have a G-V I can jump into, great. I am just saying I like the aircraft and like my company. If I wanted multi/poly-engine time and make no money I would be at NJ. This is a job. Not the ME time game.
Newbies? How long have you worked here? Do you know any of the retired/furloughed airline pilots that work here? Experience and wisdom are one thing, but risk management is another. And yes, we all can get along. :cool:
depends also....
Depends too on who's buying it and paying for the gas. I'd fly a KA-350 if someone else paid for it. No question.
As far as the VLJ's....for the dollar...I'd rather own a new Eclipse than a used PC12.
