Piedmont towed from 36L in CLT
Maybe their nose wheel steering failed. Anyone?
Wouldn't be the steering. We can MEL that and taxi around with differential braking all day. You can even taxi around with either one of the hydraulics systems out because the nosewheel steering and normal brakes are on opposite systems.
Wow, somebody is up on his system! LOL
I was at the gate that they brought the paxs back to and someone said something about a hydraulic failure. Although I'm not quite sure what exactly happened or why it required a bus ride & tow in.
Loss of #1 contents maybe?
But you still have the emergeny brake and steering. I wouldn't neccesarily want to pull up to the gate using the emergency brake but there is no problem getting the aircraft off the runway under its own power.
I know absolutely nothing about a Dash 8, but why take the risk? I'll gladly close a runway and be towed rather than risk running off into the grass or terminal.
No joke...
No #1 content, airplane no move.....
What exactly makes it risky? Certainly no riskier than taxing around on the #2 engine with only the standby pump to give you normal brakes. You are just a pump failure or circuit breaker pop away from hitting the tug at the gate if you don't get the hand brake in time. Guys are taxing on one engine all the time to save gas. The system was designed so that a loss of either hydrualic system does not cripple the aircraft.
I have no details of the incedent and am not trying to second guess anyones decision, just letting the previous poster know that a single system hydraulic failure does not rendure a dash immobile.
While I agree it may not be risky some people might not feel comfortable about it. Hard to second guess someone that is worried about the safety of the plane and pax.
I lost most of the #2 contents before and returned to CLT. Landed on the runway and ran all the checklist I needed. Looked at my FO and asked him if he was comfortable with me taxing back to a gate.
We did with no problems. Should I have been towed to the gate? Maybe, but I felt comfortable taxing and knew the limitions of the plane with the loss of the #2 Hyd System.
When you lose your #1 content in flight you are going to be moving whether you like it or not. You're going to hit the runway at about 135kts.
Well no joke, and big friggin deal. You practice no flap landings in the sim and I've used the emergency brake to stop it before. No thing there. I wouldn't taxi it though...
Hey Surf...
It's a boy!
I saw the pics! I tried to post on The Piedmont website but I issues with the internet in FLO.
Mom and Baby look great, congrats! Now get ready for no sleep for the next 6 weeks. hehehehehe you'll have a blast however.
Yeah, no number 1 contents the airplane ain't moving. Stops with the E brake can be, shall we say, brisk (ask me how I know lol).
I too lost the #2 contents once. I probably took the ultra conservative path by having the airplane towed in. Mostly I did it because there have been documented instances of total hyd qty loss through the parking brake shuttle valve... At that point I didn't know where the leak was coming from (turned out to be a bad gasket on the #2 rudder actuator). It wasn't a big deal, heck they were waiting with the tug by the runway when we landed.
I did, however, get the airplane off of the runway. I figured going into the grass was not so bad. Hitting the terminal probably was not.
Where's you sense of adventure?
Yinz are all correct- #1 dumped Q prior to takeoff (!). Pos and hold clearance with a 737 on short final- Captain moved it off the runway, set the brake, and the RUD ISO light came on. The plane, she no move no mo'.
CA is one of the very, very best we have. Greeeeat catch by the FO, who has a few years here on me. It had just dropped below 1.5 qt as they cleared the line into position.
Heard the story from the horse's mouth- of course, the Coronas were cold, we were under sail and making 6 knots on the Chesapeake... Listening to his take on the situation and how he handled it really shows how much credit is due to him AND the FO.
Same thing happened yesterday to a QX -400 on 16L at SEA. Declared a gear emergency, not down and locked I believe, appeared to land normally but shut down on the runway and was towed to the south satellite.
Yea, if that gear isn't showing locked I wouldn't move it either. At that point you would want the gear pinned then towed to the gate.
What? Q400 with a gear problem? No way!
OPEC. congrats on the crumb cruncher. I see your turning him into a little War eagle fan "Poor kid". Oh and good job. Whats the secret to having a boy? Did you take my old mans adivise and spin her around. Hope all is well with the fam.
