Personal Jet, Low Flying LearJet, Thanks Guys!
Gear Up!
~Caution Wake Turbulence~
I guess during a downward spin of all of our careers there always has to be guys that just cant act professional. Doing Rolls at 200 feet?
At least it made the local newspaper...
For the guys without jobs, maybe there will be some openings. Worth a call!!
What do you think?
Wayward Learjet buzzes Deerfield
Horrified residents watch business jet fly over Pioneer Park at 200 feet
By Jim Lusk
It was a peaceful afternoon last Sunday around 3 p.m. when suddenly a loud jet engine noise shook homes in the Pioneer Park area, bringing residents darting outside looking to the sky. The white Learjet was heading east just north of Hillsboro Boulevard and was low, very low. It caused concern throughout the area.
The jet disappeared below the tree line across Federal Highway. Then 10 minutes later it appeared again, this time heading westbound over the same area, engines roaring , less than 200 feet in the air — which again brought everyone running outside for fear that it was going to crash and this time, right over Pioneer Park, the pilot performed two barrel rolls similar to a fighter jet and soared to over 1,500 feet in seconds.
Loretta Jones, who lives in an apartment on Federal Highway said “I thought the plane was on my roof, it made me think of 9-11.”
Cindy Ritzler of NE 8 Terrace said, “We thought something was going on.”
Bill Coutts of NE 9 Avenue said, “I saw it come over the first time and then the second time, I was waiting for the fire engines to take off because I thought it was going to crash.”
A major problem could have been that, at 250 feet and 200 miles per hour, if it lost control, it would have punched through three to four homes before stopping.
A call to Paul McDermott of the Boca Airport Authority revealed that the Gates Learjet 35 tail N37TA was enroute from Palm Beach International Airport to Executive Airport in Ft. Lauderdale when it decided to try and fly undetected over northeast Deerfield, which is not controlled by the Boca FAA tower or Pompano. There is a small triangle of uncontrolled airspace right over the Pioneer Park area that increases activity and is used for flying, training or stunts.
For example, the Goodyear Blimp routinely buzzes the area and the small helicopter from Pompano airpark trains overhead. After an investigation, the Observer found that the jet is based out of Personal Jets at Executive Airport. The Flight Standards Regional Office (FAA) said they were aware of the incident and due to an ongoing investigation, they could not comment yet. As of press time, it is still unknown who was at the controls during the flight.
FAA Altitude Regulations
Sec. 91.119 - Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters. Helicopters may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section if the operation is conducted without hazard to persons or property on the surface. In addition, each person operating a helicopter shall comply with any routes or altitudes specifically prescribed for helicopters by the Administrator.
Click filename below to access file
Lear_Jet_Radio_Transmissions.AU
Flight Path
Lear_Jet_Path.pdf
At 00:54-00:59, Boca Air Traffic Controller asks the pilot "Is Hillsboro Blvd. over your air space or are we going over to Pompano at that point?" to which the aircraft replies "I have no idea."
Ha ha, so that's the article... I heard about this just the other day. From what I understand, this happened awhile ago and yes the pilots are in deep s***. Pretty damn stupid. Unfortunately I know one of the idiots involved.
Edit:
Did some searching and found the newspaper link. That actually sounds a lot worse than what I was originally told. Just love the picture of them in the article, really nice.
http://tinyurl.com/d8axdz
From what I heard, you have that backwards. It is the pilot (female) asking where Hillsboro Blvd is, not ATC. I don't see how you could get that mixed up. Are you a pilot?
I've met numerous idiots who brag about rolling their non-aerobatic ride. "It's a 1-G maneuver" "There's no stress on the plane"...etc. I have several substantial issues with this:
1. Most pilots do not have the skill to do this (aside from Tex Johnson) and a consistent 1-G is highly unlikely.
2. Other elements of the airframe, including that lead-acid battery, can't tolerate negative G. There are also oil/fuel cavitation issues.
3. Do you really want to fly this aircraft to minimums with gyros slammed to their limits by the prior pilot? Of course, you will likely not know.
You asked what I thought. Pilots who roll commercial airplanes threaten the life of every later occupant of that same aircraft. They're idiots.
I have aerobatic time and I would never do this.
......despite my signature line
"which again brought everyone running outside for fear that it was going to crash"
They meant to say "hoping that it was going to crash"
The stupidity of some people never ceases to amaze me. Especially some Lear pilots who perpetually think they're flying a fighter plane.
I remember years ago when I was a lowly 20 series Lear F/O, I was flying with an older captain who claimed to have "more Lear time than anyone else in the world." He was one of these guys who would always fly a trip long enough without stopping for fuel that the low fuel lights (or light, singular? It's been a long time since I was in one of those) were flashing in the pattern at the destination airport, etc. etc. Always doing stupid crap because he thought he knew every rivet of those planes.
One day, we were taking off from an airport in the SW. Unbeknownst to me, he had told the line guys at the FBO we had just stopped at that he was going to "give them a show" on takeoff. So after we rotated, he flew along the runway at about 20 feet, called for the gear up, yaw damper on, and flaps up, and accelerated. As we passed the FBO at the other end of the field, we must have been doing easily around 200 knots, probably more, at which point he pulled what felt like 3 G's or more and pitched up into an incredibly steep "Blue Angels" climb, leveling off with negative G's as the airspeed bled off.
Needless to say, I didn't fly with him again after that flight.
And, almost needless to say, about a year later he crashed in Texas and made about an 8-foot deep hole in the ground, killing himself and his co-pilot. Apparently ATC last talked to them when they were descending through the lower flight levels. Did he try another "watch this" moment of some kind with his inexperienced F/O, and have it ball up on him? No one will ever know.
But there is certainly truth to the "No old, bold pilots" adage.
Who knows if the female F/O (I assume she was the F/O) was new and inexperienced...maybe she had no idea that they were going to fly that low. If that's the case, I hope nothing happens to her. On the other hand, I hope the dumb@ss who was flying has everything revoked, and gets fined to boot. Maybe he or she will never fly again, if we're lucky.
that picture is photo shopped, look at the details and note under the picture.
I know in this day and age anything can be photoshopped, but I think it may be real. The disclaimer by the author might be for legal reasons so as to not implicate the pilots or provide bonafide evidence of thier actions.
Either way, it was surely too short a high. You lose your certs. for stunts like that. I mean, really... tail numbers folks?? People on the ground in areas where planes typically fly low are spring-loaded to write down your tail number or even have a zoom camerea handy for this particular purpose.
Well, I can tell you that she wasn't new and wasn't inexperienced. She's been (or I guess, had been) there for a few years. Although I didn't think she had the most endearing personality, I thought she was pretty smart and am very surprised she's a part of this. Really too bad.
Any plane can be rolled perfectly with no stress at all on anything. Its people who don't understand aerobatics that don't understand that.
Only stupid thing that crew did was to do it where people can see them.....IDIOTS!!!!!!!
Makes you wonder what they've done for the past few years in planes.
You got that right. People in that area have been trying to eliminate flying over that area for years. They have an organization that is trying daily to prove their position on the issue. Mostly old people of course who have nothing better to do with their lives...but still, they have cameras and people who actually look for things like this on rotating shifts.
That stunt won't help matters.
I live 4 miles from their.
They probably figured with the industry going to hell in a handbasket there was nothing wrong with trying to hurry their "furlough" along.
Rumor has it both seats got their certificates pulled. I thought this article would bring up some good discussion..
Is there a grace period to getting them back. I know yrs ago Northwest had a pilot lose his certs. from a "Fly DWI", then retook all the exams and BAM... NW hired him back. But can one begin the recertification process right away or does a certain amount of time need to transpire. How do these revocation proceedings work.
I can see the pilots that fly that plane after them at every FBO "hey aren't you the guys that did that low level flyby out in south florida?" Fortunately they didn't screw it up and get somebody hurt or worse...
I'm pretty sure the NW crew had their certs revoked rather than suspended. In this particular incident, I don't know what happened to the CA. But I do know the F/O had her certificate suspended. I don't know how long it was for or what else is happening. Like I said, I try not to engage in conversation with this individual, she isn't very nice to talk to.
The steamgauge gyros I fly actually have travel-limits listed in the specifications. They can't do a full 360 without recaging and restabilizing and that is very hard on gyros. Having taught acro in a CAP10b for two years, I've seen relatively few pilots who can do perfect barrel rolls. And who could do it in a transport aircraft with a much reduced roll rate perfectly on the first attempt? Again, maybe guys like Tex Johnson.
Check out youtube for his 707 roll. Then go to the collage of crashes where you'll see an SNJ, a P-38, an F-86, and a Spitfire all splatter themselves. Isn't there some Lear crew that survived a roll in the cargo world, but trashed the plane?
I guess this is a hot-button, because of all the fatalities I've seen. Go rent a Pitts, thrash it till ya puke, then go back to +/- 100 feet and 10 degrees.
These pilots demonstrate a total lack of respect for the entire aviation community and as phr8dawg mentioned a disregard for the integrity of the airframe and the lives of future crews/passengers.
Stupid move.
lots more to a simple roll than meets the eye.
In a not aerobatic craft DONT DO IT. gyros, engines, motor mounts, FCUs, oil systems, (I could go on) could be adversely affected. you can speek your 1g nonsence all day but I dont buy it.
There is a video on youtube of some guy in a 402 or 414 doing a roll, think of the rotational loads on the 600 lbs in the tip tanks. This is a obvious example.
lastly, I dont want to be the test pilot in the plane you just botched a roll in. Be a pro and dont roll.
If its done right, absolutely nothing can happen to any aircrafts airframe, period. Maybe instruments and other stuff, but not the airframe. But you're right, why argue the issue.
I'll be posting pics tomorrow of a Hawker 800XP that just came into FXE about 14 days ago and its totaled. The skin is wrinkled all the way down both sides and the wing roots are all disfigured. Morons tried to literally "snap roll it" like they were ina Pitts several times with close to FULL WING FUEL....lol. Talk about a-holes. Saw it 2 days ago in the hangar when I got back from a flight, but didn't have my camera. Its totaled and will never fly again. I think it had 1,000 hours on it. The story is hilarious and a perfect example of how doing a roll improperly will destroy a plane that is not built for it. And for the record, I don't think anyone should be rolling corporate jets. Dickhead captain tried to tell everyone he made a hard landing into FXE, yet the tires are all perfect. 9 days later, the co-pilot finally talked...lol.
I'll make a new thread.
looking forward to these beauties! hard landing... huh? jeeez... and only 1000 hours!
rolling
Back at my first corporate job there was this flight crew that rolled a GIII.
The crew came in laughing it all up and I couldn't figure out what they were so happy about. This particular crew had been flying together for about 20 years (going back to cargo, airlines, etc.) and were usually not too thrilled about flying anymore.
Turns out they thought they got away with it until the D.O. walked into the office the next day and asked,"How did some blue juice get on the ceiling!".
The crew was fired on the spot.
Good times.
Thinking about it more it wasn't blue juice, it was something from the rear galley...but still, funny stuff.
I've heard a blue juice story. Something about a crew picked up a Falcon 50 out of re-rag in Little Rock and decided to give the roll a shot on the way home. They obviously didn't keep it at 1g and ended up with blue juice on the brand new headliner. Pulled a U-turn and took it right back to LIT.
