P-56 Busted Airspace
  • Thread starter Thread starter zawillif
  • Watchers Watchers 35
I never understood not building the DCA to DCA328/10 or whatever waypoint in the FMC and using that as primary nav... it's a much more stable and accurate display. Raw data can be monitored on the RMI and/or full displayed and monitored by the PM.
Because then you're technically "building your own" RNAV departure.
If you could please explain to me where building your own RNAV overlay departure is wrong, I would appreciate it. Editing an RNAV1 departure in the database is another thing...
You're building an overlay to raw data that is more stable than the raw data while still able to be verified. There is nothing in the FARs that prevents building an FMC overlay to a raw procedure. You are incorrect that building your own RNAV departure is somehow wrong, since the user built RNAV departure is verified on raw and/or certified GPS data.
You can track a radial in flight without going to green needles, right? Along with many other examples including other airports where you track radials off the deck... DCA being the only "green needles" example that some yahoo justified their desk with that I can think of. Some guy on the CRJ decided on this and all the other operators just fell in line.
Again, demonstrate to me why this is wrong or somehow at fault in this situation, because you're going to be scratching at bare walls....
You're building an overlay to raw data that is more stable than the raw data while still able to be verified to the raw data. There is nothing in the FARs that prevents building an FMC overlay to a raw procedure. You are incorrect that building your own RNAV departure is somehow wrong, since the RNAV departure is based on raw and/or certified GPS data.
Dude, why are you turning this into a you're wrong/I'm right pissing contest? I NEVER said it was wrong, did I? The point I was getting at was that there's no published RNAV procedure to follow a specific track, such the ATL, DFW, LAX, BOS (at least used to)etc. Would it be nice if they built a procedure? Sure. If I'm not mistaken, doesn't hitting the TOGA on the CRJ when taking the runway give the FMS it's runway update, or something along those lines? If I'm wrong, sorry. Thought I remember hearing that and/or reading that when I was studying for transition training on the CRJ. Since you've flown so many planes in your short career, you should know that not ALL set ups have that capability. If no runway is loaded into the Honeywell product on the WSCOD, the ref data is hardly accurate at first. Again, like I said, RNAV departures are runway specific, the FMS may not be tracking if it NEVER got a good ref point to start with.
Again, demonstrate to me why this is wrong or somehow at fault in this situation.
Since your putting additional text and inserting ****************************** bag like quips...
Get over yourself and off your high horse.
You're putting to much additional content/edit jobs in to try to justify your point.
So, when you load an RNAV1 with the specific runway, you're getting terminal area sensitivity, right?
Reference my above point, are you SURE that ALL FMS setups ensure terminal area sensitivity when an RNAV departure isn't loaded? The point I'm getting at is the "accuracy" that's being "guaranteed" by the FMS.
Does DAL allow a manual build? As well as the ability to fly it off that using it as primary nav data?
If you have GPS available on the CRJ, then you don't even need to runway update. The GPS automatically keeps the position updated in the FMS.
Personally I'd fly it in green needles, but build the fix on the FMS for situational awareness.
That's what the check ride profile will be. If you build a route in the FMS and fly white needles YOU WILL have an FMS failure. If you build it but fly green, they have no "gotcha" to debrief.
This reminds me of the old canarsie departure profile in the sim.
I'd say it is only wrong if your company prohibits it. I have no problem if you do that and back it up with the RMI, as long as the company allows it.
Why on earth do you have this attitude with me? You responded saying that you are making an RNAV departure out of the procedure, which obviously implies that what I'm saying is wrong. I responded in detail as such, and having worked 9 out of the past 10 days and not being able to sleep last night, it took a few edits.
This discussion is about the CRJ series aircraft, not the WSCOD, which is what I based my points off of.
Oh, I don't know dude. Maybe because you took my point way too far? Even though I agreed with you, you couldn't seem to see what I was getting at and the potential danger it could get you into if the FMS has a reference probelm. THEN, you do a bunch of edit/hack jobs on your posts to insert condescending personal remarks.
That's OK, I don't think reading/comprehension has ever been a pompous southern redneck's strong suit. I didn't have an attitude with you, till YOU had one with me.
Carry on, and have a good night.
Knowing your posting history and your attitude towards me (pompous southern redneck? well, I grew up in a suburb of atlanta, so you got the southern part right...), it was a logical assumption that you were disagreeing with me and going to continue down your usual path.
Condescending personal remarks? Other than saying that you were wrong and that continuing down that path would be scratching at bare walls, I don't see anything else in there. If you take that personally, well... you need some thicker skin.
Goddamn that it ONE tall horse you got.
If you can't handle people challenging your thoughts without flying off the handle, maybe you should take some of your own advice.
Please direct me to where I "flew off the handle."
Because you wanted to turn it into a who's right and who's wrong pissing contest.
Don't know how many times I can say it, I AGREED WITH YOU!!!!!!!!
But doing it that way could open up potential problems.
Yeah... stating that in the original reponse would have been so incredibly difficult.
