P-56 Busted Airspace
  • Thread starter Thread starter zawillif
  • Watchers Watchers 35
zawillif
I'm not one to Monday morning quarterback--at least I really try not to--but twice!?? How the F--does anyone know the what exactly happened?
Makes you wonder why there is not a SID out of DCA. Following the river (which is hidden under a canopy of trees for about a mile) is not exactly good technique when you are trying to avoid a no-fly zone.
Great, now that we got the runway heading and stall thing down they're going to add a new event for PCs, something along the line of "Prohibited space, crosschecked."
Same way we had RNAV OTG issues and same way we had screwed up the OHare 5 with the 250kt airspeed limitation and missing the 5 and 8 DME altitude crossing restrictions. Complacency. The lowest common denominator wins again.
Yeah but it's not that difficult. You can see the Capitol right in front of your face, plus the Jepps, plus the permanent yellow sign by the runway that says "AVOID P-56". And you can see the river too. I can't believe that both pilots missed this both times. This is one instance where I'd actually grab the controls and turn the plane if I had to.
FOUR??? Probably the guys you always thought wer gonna screw something up but didn't say anything to keep the peace. Probably had the darn Jepp book closed on top of the O2 mask as per usual. Ah, heck, this thing practically flies itself! They should just shoot down the next one, that way we can see who the morons are.
What? - among other landmarks you can clearly see the river both taking off Rwy01 and landing 19. Intercept the 328 DCA radial works just fine also.
It's easy. Take off. Turn left. Follow the river. By the time you are ready to turn, you are above the trees...
OR you can even (gasp) plug in the radial, and fly that, just like you were IMC.
The bottom line is that people aren't reading the 10-4 or 10-10 pages, or if they do, they don't take the time to fully comprehend them.
For a rwy 1 departure...turn LEFT immediately. Someone is going to get shot down eventually if they don't.
Spoke with a friend at Potomac Tracon, this happens a lot more often than we may think.
If anyone wants to take a stab at who started service at DCA, you may be interested in knowing that said carrier busted P-56 this week too...
From the 'digital terminal procedures' the only FAA published departure procedure for rwy 1 is
DEPARTURE PROCEDURE: Rwy 1, left turn as soon as
practicable, intercept DCA R-328. Climb to 5000 or as assigned.
You follow the river on the approach to 19, not the departure. If you are filed IFR the only FAA accepted departure procedure is to tune the DCA VOR and track the 328 radial out. Then stay on that radial until ATC tells you different. Its been that way for many years. And I used to take a J-3 Cub with nothing but a hand held radio to DCA for lunch.
If you visually follow the river out you will make a right turn off the radial at the Roosevelt Bridge that will result in a ground track that points straight at the White House. It is a right turn the controllers don't expect, since it is not a published procedure. Following the river at 500 feet was the VFR procedure years ago when you departed runway 4.
Most of the P-56 violations by air carriers result from automation dependent pilots using standard profile TO procedures. The automation won't respond fast enough and they get a close up view of the Washington monument. The CRJ will do it if you have the radial twisted in and a heading of 300 bugged before you start the TO roll. Then select 'NAV' mode prior to 200 feet. It's a whole lot easier to hand fly it without the FD. .
