Seems like Johnnie O. is concerned about attrition, especially in the "P.S." part. Is it really that much worse on the UA side then in the other parts of the Mesa operation?
Sorry for the long post. Thought you Mesa guys might want to read it if you haven't already.
Dear Alex,
You have asked me for our thoughts in regard to improving UAX/Mesa performance and we appreciate the opportunity to share our views with you. We believe the following recommendations may be applicable not only to Mesa, but to some degree the entire UAX program and in particular its 50-seat regional jet component. There are a number of significant operational issues that working together we believe can be resolved in the best interests of our customers, employees and shareholders.
In order to best appreciate our recommendations, I thought a little history would be beneficial. After the poor operational results of the summer of 2006 Mesa has worked hard and focused almost exclusively at addressing UAX operational issues. Through this work we have uncovered a number of issues which United and Mesa were either unaware of, or did not fully understand. United's "56k baud" communication system, CORA, the concentration of Mesa operations in high ATC/weather cities, Mesa's contract maintenance and aircraft cleaning program, the lack of adequate ground equipment at United stations, RON requirements, delayed aircraft interior specifications, fuel saving initiatives, bag delivery / ITE, station handling and accountability, are just a few of the many issues we have discussed together. While progress has been made, there remains significant room for improvement.
Given Mesa's operational performance at our other partners as measured by CCF, TCF, D0, A14, MBR, customer complaints and DIR, we continue to believe issues often raised by UA as "Mesa issues" are systemic to UA and a direct result from differences in UA's operational protocol, geography, approach to customer service and accountability. For example, in March, Mesa's controllable completion rate for UAX was 99.4%, roughly the same as for our other operations. Our total completion factor, however, was 94.4%, 4 points lower than what we achieved at Delta and 4.3 points below what we achieved at US Airways. While United continues to point out Mesa's ability to "recover" as the issue, the other UAX carriers have almost identical numbers when compared on a hub by hub "apples to apples" basis. Like Mesa, these carriers do not experience the same disparity between total and controllable completion factor with their other partners. While we appreciate the difficult operating environment in a hub such as ORD, we believe UAX significantly compounds this difficulty by effectively "over scheduling" the hub making it impossible to maintain schedule integrity in anything less than optimal weather conditions. Given ORD experiences irregular operations almost two out of every three days, this approach seems to be counterproductive. As a result, costs (much of which are borne by Mesa) are significantly higher than anticipated, crew disruption is far higher than experienced in our other operations and customer satisfaction is significantly lower as measured by DIR. For example, using the exact same customer satisfaction survey as utilized by UA, Mesa’s US and DL operations receive DIR numbers in the 30’s and 40’s, respectively as compared to the low 20’s in our UA system. The previously mentioned scheduling issues are further compounded by CORA. While CORA impacts all UAX operators negatively, its effects are most pronounced on UA’s 50-seat operations. Neither of our other partners utilize this type of system – in fact DL discontinued a similar system due to the operational disruption it created at its regional carriers. Given our early conversations regarding CORA and the subsequent analysis done by UA in regard to schedule difficulty based on “average delay minutes”, it was clear (CORA slot reallocation was not included) that even people intimately familiar with regional operations did not fully understand the impact CORA has on small jet operations. It is important to recognize the many statistics regarding delays and reassignments and schedule adjustments are more than just numbers, they reflect real disruptions to our passengers and flight crews. It is important this fact be kept in mind as Mesa’s crews repeatedly deliver exemplary service under extremely difficult conditions.
MORE>>>>>>
Dear Alex,
MORE>>>>>>
