OK I give up. Why do CRJ spoilers click instead of a smooth motion
Abernathy
Truthiness
I've been wondering on and off why the CRJ engineers put the seemingly inexplicable "click" system in the spoiler system, making for unnecessarily choppy spoiler deploy and stow cycles? I've often thought (while staring out the window during the Captain's introductory briefing), about what the possible reason could be, and I have yet to come up with an answer.
So, I figured those of you who have more stripes than I do might know.
It's because it's designed by French Canadians! Forget Mesa, the French suck!
You can deploy them smoothly though if you don't just yank the handle and use it as an on/off switch!!! Brace your hand on the pedestal and you can operate them so you won't even feel the notches.
Not "you" personally but just in general....don't take offense
Why do captains like to yank on the spoilers like the e brake in their rice rockets. Pretty annoying. You can still be pretty smooth even though it clicks.
I didn't kinow Bill Lear was a Canadian.
After riding on the 900's, it seems they eliminated the click.
On the 200's, all I did was just anchor my hand to the pedestal and ease the handle into the detents. It's enough to make you wanna choke a b!tch when riding in the back and you get someone that clicks them... thunk thunk thunk.... thunk...
Sounds kinky... Maybe you should share this technique with the Gen. He could try it out on Ned the next time he gets back to LBB (prolly next week-that horndog has a rep.)
I believe there are multiple reasons for why the spoilers click. One reason is so they stay in position. Another reason is a from a human factors aspect. For the same reason that most of the knobs on the FCP have different feels to them. Believe it or not there is a subconscious knowing of 1 click vs. 6 clicks.
going from the 70/90 back to the 200. The 200 has to be the worse plane out there. Never seen so many limitation and waivers for an airplane. They can't phase this thing out quick enough
They click into place to allow the passengers to realize the jackass flying doesn't know how to plan his descent properly.
Sounds like the technique I use when I'm with crj567's mom!
You should hear the noises that woman makes!
And what's the deal with airline food these days......
If it weren't meant to be used, the handle wouldn't be so big, and the thing would be so corroded it wouldn't move............ It's not a measure of poor planning, but a measure of efficiency. It takes cohones to plan ones descent to include the spoilers with no other way to fix the "poor planning" : ) The number one pieve I have is the ripping of the spoilers from full stow to full-pull and back in again. Gotta love peeling your face off the glareshield only to have it smashed back through your forehead with the stow cycle.
Also, as a passenger, I'd preffer the smooth application of the spoilers in the descent for a short approach as opposed to flaps 20, which seem to change nothing but the "angle of the dangle".
Ive found that if you slowly pull the lever out of the detent and simultaneously lift on it as you pull back...putting upward pressure on it as you increase the amount of spoilers...it tends to deploy MUCH smoother and not give that annoying thunk noise and bump in the ride...same thing when stowing them....so lets recap...like all of your mothers...just give it a gentle pull upwards and watch it come out nice and smooth without any bumps.
