S SSDD Well-known member Joined Mar 20, 2002 Posts 1,128 Sep 30, 2011 #1 of 14 What is the min crew O2 pressure for the E145 with a jumpseater? Thanks
MACH-TUCK Well-known member Joined May 28, 2005 Posts 285 Sep 30, 2011 #2 of 14 SSDD said: What is the min crew O2 pressure for the E145 with a jumpseater? Thanks Click to expand... Why??
IBNAV8R Stand-up Philosopher Joined Jul 3, 2008 Posts 843 Sep 30, 2011 #3 of 14 Got denied the JS due to low O2?
A asayankee Well-known member Joined Jun 7, 2006 Posts 446 Sep 30, 2011 #4 of 14 Do you work for GoJets?
S SSDD Well-known member Joined Mar 20, 2002 Posts 1,128 Sep 30, 2011 #5 of 14 Got denied...don't work for gojets.
H hockeypilot44 Well-known member Joined Feb 26, 2005 Posts 893 Sep 30, 2011 #6 of 14 It varies with temperature.
Aerosurfer I envy the Gaut Joined Oct 6, 2003 Posts 233 Sep 30, 2011 #7 of 14 1500psi can be adjusted if the temps are not standard.
B BrickTop Well-known member Joined Jan 26, 2006 Posts 554 Sep 30, 2011 #9 of 14 Do you wear hair gel, leave your sunglasses on your head or walk with your ipod in ears while in uniform? Last edited: Sep 30, 2011
V vandypilot Well-known member Joined May 16, 2002 Posts 48 Sep 30, 2011 #10 of 14 Also depends on if you carry a back pack
