Notes from the Delta Conference Call...
Sedona16
No thread specifically on this yet so I thought I would start one. I am still listening to it now but key points I have so far or at least what I interpret:
1. There is something in play for an Alaska purchase.
2. Anderson spoke of the need for fleet consolidation (I think the 747's will go away within five years).
3. Anderson said pilot productivity in the form of block hours per pilot will be industry leading. I dont like the sound of that.
Yeah.....productivity.....the horror!
Productivity in general is good for the pilots and the company. Pushing pilots on block hours (ie more and more time away from home and less time with family etc) is not desirable at all unless you are a loner and money is your only objective. All things being equal the sweet spot for pilots is high hourly compensation on yes productive trips but in my book, maximizing days off is of equal or more importance. Each to their own I guess.
4. Industry capacity down 14% from 2007 to 2009. Delta plans their domestic capacity to be down 20% through 2009.
5. There is currently a huge barrier to entry (finaly!) to new start up LCC's etc due to the credit markets being down and near impossibility to aquire airplanes for a start up. This means the playing field will either stay the same or improve minus the obvious reductions in people that are flying as of late.
6. Paid an average of $100 a barrel for oil in 2008. Right now it looks like $50 a barrel or less for 2009 equating to 5 billion dollars in saving. This could make for some impressive profits (a good place to start when pilots are looking for healthy pay raised in four years).
7. Bastian says Delta's costs going forward will be 10% to 15% lower than the competition.
8. Spending 200 million on technology and information systems to "do it right and not skimp".
9. The new agreement that was just struck with American Express is big and was mentioned several times. Worth 15 Billion dollars over the next 7 years and got one Billion in prepayment adding to current liquidity which I believe is around 7 Billion.
10. Will go from non existant player NY to Asia to the most dominant.
11. The Narita flight out of SLC will be with an A330-200
12. The route planner Hauntein (not sure how you spell his name) made a point to specifically state when you combine Delta with Alaska you now are the largest carrier in 3 out of the 4 largest gateways on the west coast (Seattle, Portland, LAX....with SFO being the fourth and pretty much still owned by United).
Just a couple of points open for discussion.
The first is that as with the NWA merger being more-or-less a foregone conclusion from the beginning, I think the Alaska thing will be the same way.
It appears to me that Delta is simply buying up the competition, so to speak.
Secondly, with a third airline possibly in the mix, it would make sense that there has to be some kind of consolidation at some point. That means overlapping routes and finally furloughed pilots.
Growth happens over time in a give and take fashion.
13. As others have noted Hauntein said "yesterdays trash is todays treasure". He said the DC9 six months ago was not a good airplane to operate with fuel so high but now it can be a good asset to fill in the needs of the route with a 100 seater (presumably in the place of two less economical 50 seat RJ's). Also mentioned ealier in the webcast delta has removed 150 RJ's from what they had in 2007. Probably looking to replace a few more now with these DC9's in my opinion.
There was not very much overlap between NWA and Delta and this is a large reason in my opinon why it got approved. Likewise there is little overlap between Alaska and Delta and unless the goverment takes a stance that Delta is just getting too big and therefore has monopolistic powers I do not see why it wouldnt be approved as well if the same criteria is used. I think there will be furloughs but not due to alot of overlap. More due to greater efficiency in how destinations are served with less airplanes, utilization of hubs and the ability to trim the 10% for routes that were losers on both pre merger airlines and focus only on the money makers in a bad economy. Still stinks no matter the reason. That said, in three years or so with alot of money in the bank and returning economy I believe the furloughies will all be back and heavy hiring under way for further expansion. I could be wrong on all this and ACL65 probably has a better idea from an insiders perspective.
As another alternative and hopefully Delta management would understand the importance of taking care of its newest pilots who are about to spend the next 15 to 40 years operating thier aircraft more SILS (reduced hour schedules) would be used to prevent furloughs in the interum.
Bullsh*t. They are looking to replace 50 seat rj's with 76 seat rj's. The point of outsourcing to the the regionals to begin with was to attack our wages. They are never going to go the other way. You will never see an rj replaced by a mainline aircraft. You are way too optimistic. We should have gotten way better scope in regards to the 76 seater. This is going to bite us in the ass.
I dont dissagree with what you say. I never said all RJ will be replaced with DC9's. I believe what is stated or implied in the webcast is some replacement of some RJ's with DC9's. I absolutely agree Delta pilot leadership (I wasnt on the property) completely blew it on scope and it continues to be a problem and yes they are looking to add 76 seaters and larger if they can get away with it. I think we can agree it needs to be right at the top of the list of priorities, at least holding the ground we have now and push to bring "RJ" on as mainline flying or get rid of them altogether.
PS- Please dont attack me for reporting what was said in a webcast. What I speculated was not all inclusive and did not contradict what you said.
Your thinking is pilot centric. 50 rj's will be replaced by larger equipment and larger RJ's routes will be replaced by DC-9s. Pilot wages are just one of the many costs to look at when choosing which aircraft will make up Delta's new fleet.
Did you think about the offset cost savings of having one flight versus two? One ground handling rather than two? One landing fee rather than two? One aircraft that is paid for rather than two lease payments on RJs? One crew to pay rather than two?
The BOTTOM LINE is that when you pull a greater number of passengers out of Northwest and Delta between two city pairs you can UP-GAUGE equipment and SAVE money. That is a huge benefit to the operational costs of Delta going forward and therefore scope by the way of economics.
Hockey's correct... and Delta can't get out of any of their fee for departure contracts. ( we will see if the Mesa case makes a liar out of me, but so far Mesa's fate hangs on their insolvency)
Delta is trying to trade big RJ's and contract extensions for small RJ's and F4D cancellations. Thus far the regionals are saying "no thanks, a contract is a contract."
Fins, do you have any recollection of the agreement Delta struck with Skywest when Skywest purchased ASA? I seem to recall there was a ten year agreement signed by Leo with skywest but Delta could get out of if but it would cost a few hundred million dollars?
14. The system that will allow flowing aircraft freely from both the NWA fleet and DAL fleet and how crews follow planes etc will not be in place until fourth quarter 2009. They are "taking their time" to put this into place to avoid the fiascos US Airways ran into.
15. Based on what was said at 2:54 on the webcast it doesnt sound like there will be much moving of airplanes due to several issues including the required necessity for automation at the Delta Operational Control Center, etc until the SOC is achieved. The second the SOC is finished Glen H will have everything pre planned and lots of moving of aircraft will happen at that time.
The training on the other hand will be "pre loaded" so that when SOC is achieved the new plan hits the ground running. Based on this information I would think the bases/aircraft and bidding will be announced and take place before SOC. They didnt specify FAA approval vs SOC regarding training.
16. Money is being spent on the electronic bag tracking system and this continues to be a top priority to be top of the industry.
17. Subsidiary business will continue to produce a significant amount of revenue such as:
Cargo
Maintainence services
Selling frequent flyer miles
Selling ala cart revenue generators.
LCC will be operating at a disadvantage with inability to grab much if any premium revenue.
18. Fuel Hedging:
Systematic
Delta is currently using a combination of call options, swaps and collars. Most of the current swaps and collars will be out by second quarter 2009.
Currently purchasing fuel hedges for 2010.
19. Current aircraft orders (20) not inlcuding 787's
777, 737-700 and CRJ900
No major refleating at Delta. They are content with what is on property and adding a few airframes as it makes sense but no big captital expenditures in the near term and refleating is still quite some time out.
20. Pension funding is an increasing expense (presumably part of this is the now inherited NWA pilots pensions).
21. There are 80 hotels that are already shared by Delta/NWA crew....more on the way.
22. I kept hearing "getting the costs out" and referring to aircraft and people. Of course the non pilots are being offered early retirement programs. I'll let everyone here connect their own dots on how the costs with airplanes and pilots we dont need will be removed.
Thats about all I got but I was listening loosely. Anybody else care to chime in with your thoughts please do.
OK I checked the slides and the aircraft still coming are
6 777
6 737-700
8 CRJ900
A couple other points I thought were worth noting from the slides. Based upon the revenue/profits debt will be paid down very rapidly...from its current 15 billion (this is total combined debt of the two carriers) down to 6.2 billion within three years. Liquidity will stay high maybe even increasing from the almost 7 billion in the bank right now (including the 1 billion received from AMEX today). Also there will be very little taxes to be paid with all the write downs carried over from the past couple years (almost 15 billion when combining both DAL and NWA).
