CWGrizwald
- Nov 9, 2004
So much for getting our G450 into SMO from now on, which is fine, as even the 450 is a bit big for that place.
Santa Monica Airport
Office of the Director
3223 Donald Douglas Loop South
Suite 3
Santa Monica, CA 90405
(310) 458-8591
FAX (310) 572-4495
April 10, 2008
Re: Santa Monica Airport – Implementation of Ban on Category C and D Aircraft.
Dear Santa Monica Airport User:
On March 25, 2008 the Santa Monica City Council adopted an ordinance restricting aircraft
operations at the Santa Monica Municipal Airport (SMO) to aircraft designated by the
Federal Aviation Administration (FAA) as Category A and B aircraft. The Santa Monica
Airport is designed to handle such aircraft, which have approach speeds of less than 121
knots. Operations by Category C and D aircraft are prohibited by the ordinance.
The new ordinance will go into effect on April 24, 2008, after which only aircraft in the FAA
designated A & B categories will be allowed to operate at SMO. Attached for your reference
is a table explaining FAA aircraft approach speed categories. Also you can visit the
following FAA link to determine which category your aircraft falls under:
http://www.faa.gov/airports_airtraffic/airports/construction/aircraft_char_database/.
Note: In general, the new ordinance provides that, except in the case of a bona fide
emergency, no person operating a category C or D aircraft, as defined by
FAA’s standards, shall land or depart from the Santa Monica Municipal Airport
after April 23, 2008. Penalties for violation of the Ordinance include
misdemeanor prosecution with punishment of a fine not greater than One
Thousand Dollars ($1,000) or imprisonment in the County Jail for not more than
six months, or both. The Ordinance is available for viewing at www.smgov.net
or www.santamonicaairport.org (airport website).
Users of Santa Monica Airport, who utilize fractional share aircraft, may want to consult with
their fractional share operators. As noted on their websites, the following fractional
operators allow their participants to change to aircraft in compliant categories:
Netjets: http://www.netjets.com/The NetJets Program/netjetsprogram_overview.asp
Flexjet: http://www.flexjet.com/home.html; and
Flight Options: http://www.flightoptions.com/about_overview.html
Over
I also advise that you periodically check the Santa Monica Airport’s internet site at
www.santamonicaairport.org for updates.
Sincerely
Robert D, Trimborn
Airport Director
FAA Designated Approach Categories
According to FAA Advisory Circular 150/5300-13, Airport Design, an aircraft’s approach
category is based upon 1.3 times its stall speed at the aircraft’s maximum certificated
weight.
The five approach categories used are as follows:
Category A: Speed less than 91 knots
Category B: Speed 91 knots or more but less than 121 knots
Category C: Speed 121 knots or more, but less than 141 knots
Category D: Speed 141 knots or more, but less than 166 knots
Category E: Speed greater than 166 knots
Suite 3
(310) 458-8591
FAX (310) 572-4495
April 10, 2008
Over
Sincerely
Robert D, Trimborn
Airport Director
weight.
