G-force
It is shameful the extent that you will go to make a point that is untrue.I hope someday you will be able to take the high road instead of the lowest.You give North Carolina a bad name and I feel sorry for all the good people who live in that state.Yes,it is true G-force has been fired from every 135 operation in the midwest.G-force said:Not every aviation job,just a couple of the worst bottom-feeders,and one the worst was at LNK,but it had great potential to be one of the best had the so-called pilot/mgrs knew anything about mgmt.or had any respect for the FAR's,which they did not.
I would not call,pulling CB's and causing the maint status on several turbo-props, 2 jets, and several piston twins to be falsified,because the time flown does not correspond to the HOBBS METER. Pilots flying those aircraft could have been in severe JEOPARDY from the FEDS in a ramp check!!!
Go figure!!
