Turtle21
- Feb 8, 2007
The snowball rolling down the hill is irregular operations. Say you divert, hit the 8 hour point, however now we can fly to 9. But the scheduled flight is 61 minutes from divert to overnight, now you're done when before you could have kept going till you cried uncle.
Or better, lets say you hit the 8 hr point after you diverted, the flight from divert to overnight airfield is 30 minutes with a 31 minute divert flight because it's still at minimums. I consider I will need to account for all possible flight time, including another divert. And yes, I have diverted twice in one day.
It looks like you can extend past the scheduled FDP for unforeseen operational circumstances (up to two hour extension), with different conditions prior to or after takeoff. Also some pretty strong restrictions and reporting requirements if the extension is longer than 30 minutes.
§ 117.19 Flight duty period extensions.
(a) For augmented and unaugmented operations, if unforeseen operational circumstances arise prior to takeoff:
(1) The pilot in command and the certificate holder may extend the maximum flight duty period permitted in Tables B or C of this part up to 2 hours.
(2) An extension in the flight duty period under paragraph (a)(1) of this section of more than 30 minutes may occur only once prior to receiving a rest period described in § 117.25(b).
(3) A flight duty period cannot be extended under paragraph (a)(1) of this section if it causes a flightcrew member to exceed the cumulative flight duty period limits specified in 117.23(c).
(4) Each certificate holder must report to the Administrator within 10 days any flight duty period that exceeded the maximum flight duty period permitted in Tables B or C of this part by more than 30 minutes. The report must contain the following:
(i) A description of the extended flight duty period and the circumstances surrounding the need for the extension; and
(ii) If the circumstances giving rise to the extension were within the certificate holder’s control, the corrective action(s) that the certificate holder intends to take to minimize the need for future extensions.
(5) Each certificate holder must implement the corrective action(s) reported in paragraph (a)(4) of this section within 30 days from the date of the extended flight duty period.
(b) For augmented and unaugmented operations, if unforeseen operational
circumstances arise after takeoff:
(1) The pilot in command and the certificate holder may extend maximum flight duty periods specified in Tables B or C of this part to the extent necessary to safely land the aircraft at the next destination airport or alternate airport, as appropriate.
(2) An extension of the flight duty period under paragraph (b)(1) of this section of more than 30 minutes may occur only once prior to receiving a rest period described in § 117.25(b).
(3) An extension taken under paragraph (b) of this section may exceed the cumulative flight duty period limits specified in 117.23(c).
(4) Each certificate holder must report to the Administrator within 10 days any flight duty period that exceeded the maximum flight duty period limits permitted by Tables B or C of this part. The report must contain a description of the circumstances surrounding the affected flight duty period.
