ImbracableCrunk
Unregistered Un-User
- Feb 5, 2003
Straight from ALPA's Guide to Flight Time Limitations and Rest Requirements
Q-3. A flight crewmember has flown 30 hours in a six-day period. On the sixth day, can the carrier assign the crewmember to fly a ferry flight following the completion of the revenue flying that will cause the crewmember to exceed 30 hours of flying within a seven-day period?
A-3. Yes. Ferry flights are normally conducted under Part 91, and the flight-time limitations are applicable only to Parts 121 and 135. Some carriers do apply Parts 121 and 135 to ferry and repositioning flights. If you are unsure as to whether it is Part 91 flying, you should make appropriate inquiries. However, ferry flight time under Part 91 must be counted as “other commercial flying” to determine compliance with the monthly and yearly flight-time limits. Moreover, if the ferry flight time is accumulated before attaining 30 hours of flight, then it must be counted in determining the 30-hour limitation.
Q-3a. A pilot is scheduled to fly 7.5 hours with a tail-end ferry of 2 hours for a total flight time of 9.5 hours. This example raises two questions: (a) can the pilot fly the ferry flight since that will cause him to exceed 8 hours without an intervening rest; (b) how much rest must be scheduled?
A-3a. (a) The pilot can operate the ferry flight since it follows revenue
flying. If the ferry flight preceded the revenue flying, the pilot could not complete the schedule because it would exceed 8 hours without an intervening rest. The actual time flown must be counted towards the weekly, monthly and yearly time limitations.
(b) The pilot must be scheduled for 9 consecutive hours of rest. This rest may be reduced to 8 hours if the crewmember is given a 10-hour compensatory rest that must begin no later than 24 hours after the commencement of the reduced rest. Ferry flight time must be counted to calculate the rest period.
