Need some ATP written help
SIG600
Total Time
375
Gents, I downloaded Gleims ATP test prep, figured I'm deployed so I may as well start working on my next licence/rating. Some questions for you guys in the know:
Are there seriously still LORAN-C questions on the ATP written? Didn't LORAN die a quiet death several years ago?
There are several different ATP writtens I can study for, 121, 135, and host of other ones. Assuming just the straight 121 is what I want?
There are performance data sections for the DC-9, 727, 737, and B-1900. Do I need to study up on all of them, or can you pick one when you walk in the door?
Thanks in advance, any other input appreciated.
JAFI
Total Time
8000+
Have you completed the Commercial exam? Your info says PPL.
What, you don't want the ladies to answer?????
As far as I know Loran C is still being used but not for long. The Homeland Security Appropriations Act for Fiscal Year 2010 allows for termination of the LORAN-C signal on January 4, 2010. We will see....
Study one or the other. I studied the 135 because I was flying 135 at the time so it worked for me.
If you pick the 121 exam you will get performance questions for the larger aircraft, if the 135 you get the smaller aircraft questions. Look in the back of the book you may see a guide to question numbers for each exam.
wrxpilot
The proud, the few
Total Time
First of all, thank you for your service! A lot of us are thinking about you guys and girls as we approach the holidays.
Yeah, unfortunately they still have some very outdated questions in there (LORAN C, NDBs, etc). Fortunately it's only a very small portion. The worst part about the whole written is the flight planning questions... They are absolutely ridiculous and have nothing to with reality. Just memorize them and move on.
You can do either 121 or 135, it doesn't matter. No employer will ask you which written you did, nor would they care. I did the 135 written as I was much more familiar with those regulations. Good luck!
SIG600
Total Time
375
Yeah, I have more than enough time.
Thanks wrx, how did the systems/etc. questions work? All airframes fair game or pick one?
Jafi, thanks, sorry didn't read your whole post firt time around. So there's no difference in the ATP ticket you put in your wallet regardless of which one you take?
340drvr
Total Time
7000
No difference whatsoever on your certificate once you get the rating. The different airframes, your test will randomly pop up with one or the other, no way to pick and choose. IIRC, each "series" of flight planning questions (i.e. wgt/balance, T/O, fuel burn, ldg, etc.) will stick with one airframe. (It was a while ago, so may be different now............no comments about Ford Tri-motors, it wasn't that long ago!)
340drvr
Total Time
7000
Sweet, so I get to learn them all?
More or less, yes. At least familiar enough with each so that you can easily perform any appropriate calculations. You will be provided with any/all necessary tables/charts/figures, a la AFM, for whichever airframe, so as long as you know how to use the various tables, it shouldn't be a big deal. Good luck!
transampilot
Total Time
>3000
When I took my ATP written I was able to choose between 121, or 135. I knew 121 regs better but the new job I received at the time was 135, so I took that instead. Would have been easier for me to pass the 121 version but at least it made me study the regs for 135. As for performance the airplanes are broken down into 121 and 135. Anything in the section you are taking you could be asked. I used gleim to study because it organizes the different sections much easier. The asa version you have to look at the title above each question to see if you need to study it 121/135/DX. As said above thank you for your service and be careful over there.
wrxpilot
The proud, the few
Total Time
I believe it was just specific to the airframe under the regs... So if you're doing 135, you'd be dealing primarily with the 1900. Also, it doesn't really get too specific about systems, but there will be a lot of questions about performance and W&B. Can you receive mail where you're at? Maybe I can send some stuff out that would be helpful...
SIG600
Total Time
375
I'm actually on a short tour on the beach in a small middle eastern country. Headed back to the boat in a week. Thanks for the offer though. Planning on staying in the military for a while, but my commercial ticket is getting old, and for some reason I just feel like getting my ATP since I have the requirements met.
gcletsos
Member
Total Time
5000+
Go to ALLATPS. $295, including cost of test. Best deal out there. I made a 94 on my test.
gcletsos
Member
Total Time
5000+
Yeah. But how long did you study. I walked into ALLATPS in the morning and passed my written by 5pm that same day.
For an extra $100 I think its well worth it.
sqwkvfr
Baseball junkie
Total Time
a lot
A few different periods, at my convenience, for a total of about 12 hours.
I didn't have to give up an entire day to do it, saved a lot of money, and didn't contribute one thin dime to ATP.
Priceless.
pin727
Total Time
7000+
I back up this 100% i got 96 in at 8am test at 430pm in FLL next door to sheltair!!! best money spent!!!
avbug
Total Time
n/a
The only reason for having 121 or 135 selections is to make it easier on the person taking the test. The FAA recognized that some test takers are employed under Part 135, and thus geared the test toward material they might know...and likewise for those employed under Part 121 the test is oriented toward Part 121 regulation.
If you're flying 135 and take a 135 test, you won't get B727 questions.
The performance information isn't there to memorize; it's there to show that you can calculate performance, and that's all. It's spagetti charts and tab data. That's it. They want to know if you can find the data, perform calculations, and interpolate. That's all.
Given that any commercial test prep book gives you the answers and the questions verbatim (making the FAA test a laughing stock, globally)...why on earth would you waste your money going to ATP's or any other testing service. You can study it on your own and do just as well.
Bear in mind that while you can cheat your way to a perfect score by having someone drill the answers into your head, the idea is to learn the material, instead. Do that.
