That answer sure runs counter to everything I ever learned and ever taught. I don't have a Flight Training Handbook at hand, but I can see in my mind everything it says about not attempting a 180 back to the runway.
After all of his training was done him and his sim partner were able to just take off and go have fun, like buzzing houses and stuff or just whatever; so he wasn't really expecting an engine failure, both engines at that. Anyway, when he was at 800' AGL the instructor pulled both engines. He was showed that if you put the gear down immediately, feather immediately and enter a 45 degree bank in a little nose down attitude (don't remember what speed he was supposed to be at, but I'll find out from him) and turn all the way around to the runway, you could land with no problem. Although, the instructor said it won't work for 700', it's just simply too low.
If you have a crosswind, you always turn into the wind to decrease your turning radius.
Of course, there is no RIGHT answer, but I was surprised to hear what the instructor had tought him the plane could actually do.
Well, I think that's it. If anybody has any questions I'm sure he could help you with anything you come up with.
There's two things on this thread that I don't understand.
1) Why is everyone worried about getting the gear down, the airplane will glide better and farther with it up and in most cases when pilots try to keep equipment damage to a minimum (returning to the airport for example) they end up with dead people. Just land with it up! It is imperative the gear be up if landing in water!
2) You fly like you train, If this instructor is training pilots that this turn is possible sooner or later one of these pilots will experience this or a similar situation and try it, unsucessfully.
Does this instructors employer know he is doing this?
I don't have a link to post, but if you look back to this past summer in the preliminary accident reports, you will find a Navajo accident at the Reading Regional Airport, with the location given as Bern Township, PA. After departing 36 and experiencing some kind of failure (smoke reported from one engine) he turned left to return to the field. He passed the end of 13 (where I would have put it, with one engine running) and made a big hole in someone's back yard. Some witnesses reported a roll, and some witness reports seemed contradictory. None of the information indicates why he would have lost control, as there were several places to belly it in nearby, and nothing indicates why an empty Navajo, cleaned up and flying at blue line, couldn't make it back to the runway on one engine. If you fly a Navajo, you'll wonder what went wrong.
Would I try a turn back? In a sim, sure. If I had the failure described above, I'd feather and head for the beach at 78 kts., gear up.
Interesting. While not a Navajo pilot, I'm a member of the..... don't turn back, don't lower the gear, keep flying 'till it hits the softest spot you can see in front of the airplane crowd.
It matters not if you feather, lowering the gear is the least of your problems. Why bother? Better to spend what little time you have trying to restart, but don't stop flying while you're trying. Kill the electrics pre impact. On the way down, tighten the harness and belts as much as you can. If possible, get something open so that you can exit when it stops (even if you have to put it in the water). Attempts at the spectacular most often result in spectacular headlines in the obituary column.
Question to the maker: Out of curiosity, what is this instructors flying background and how many times has he successfully completed the task he advocates in a real airplane? Of any type.
Sims are great training tools, but I doubt there exists a level D sim for that type aircraft. The light twin sims that I've seen don't even come close to duplicating the true flight characteristics of the real thing. Am I outdated on the technology of Navajo simulators? The one's I've seen were much more of a training device than a simulator.
I think someone once said something like: There are bold pilots and there are old pilots, but there are no old, bold, pilots.
I think that going back for the runway at 800 AGL is a mistake! The sim may do it but most of the Navajos that I've seen are not in the pristine condition that the sim emulates. The scenarios that cause this are usually two things: 1. fuel contamination or 2. incorrect fuel configuratution. with that in mind be aware of the given scenario, always prebrief yourself on a failure such as that mentally before departure. (always have a plan!) Next adhere to procedure and then start improvising within reason. My personal preferance is: Beach, trees, rocks, water in that order. Water is never a good option!!! Someone is going to get hurt everytime and may not get out of the airplane. Remember broken people cost more then broken airplanes! If you turn back for the runway at 800 AGL your concern is the airplane not yourself or the passengers.
My 2 cents Woody
