MY throttles, pal!
GravityHater said:
After I stand them up, I ask the FO to 'Set Power, please' and this one guy seems to take forever tweaking and adjusting.... soon it is V1 and instead of removing MY hands from them and going to the yoke, I find HIS hands still on them!
How long does he get - crap I can usually set them within 1% in 5 seconds.
I am looking for any suggestions about the topic before I bring it up with him.
Just out of curiosity, what are you flying?
'Sled
EagleRJ said:
I've seen FOs do that recently, to the point where we're passing 100 knots and he still doesn't have the power up all the way! That may be smoother for the passengers, but your takeoff performance numbers go right out the window when you do that.
Perhaps there are some training and standardization issues involved here if the FOs don't understand why that's not a good idea. Perhaps you, as the captain, should step in and help the FOs learn what you have just shown you already know. They're only trying to do what they perceive as the "right thing". Help them see what that really is.
Our POH states that the power will be set by 60 knots, if that helps.
Thedude said:
Can you plz enlighten me on what this is. A little more detail..i have never heard of this.
I heard that some people flare the airplane or some nonsense like that. I like to pretend like it's a carrier landing and just fly it right inot the deck. Makes me feel like I land with authori-tie.
This one is way too easy guys. its hard to believe there is a discussion. All performance figures for runway required etc are based on max (or takeoff) power being set BEFORE BRAKE RELEASE. The manuals on our aircraft even give us the T/O N1 setting. What are you guys doing fooling with the power while the aircraft is moving.
There are perfectionists amongst us
These are the guys who are tweaking the power until it's *just* perfect, no matter how long it takes...
...when they upgrade, they'll be the same ones who constantly adjust the power and put their hand on the gear lever when they want it down.
Deep breath.
It's called a rolling takeoff. I haven't done a static takeoff in ages.
That's not exactly true. It varies by aircraft type. Many aircraft have numbers for rolling takeoffs, with additional data for a "static" takeoff when every last bit of performance is needed.
When's the last time you took an airline flight where the crew made a static takeoff?
Some aircraft don't even allow the static takeoff under conditions of strong crosswinds. With the combination of high power and a strong crosswind across the intakes, there's an increased possibility of compressor stalls.
i agree with tonyc's first post in this thread. it should be taken care of in the t/o brief (thrust set by 60 kts to x check by 80 or whatever) but taking longer than a few seconds for N1 is pretty silly; just standing the sticks straight up usually gets it very close anyway
"That's not exactly true. It varies by aircraft type. Many aircraft have numbers for rolling takeoffs, with additional data for a "static" takeoff when every last bit of performance is needed.
Some aircraft don't even allow the static takeoff under conditions of strong crosswinds. With the combination of high power and a strong crosswind across the intakes, there's an increased possibility of compressor stalls."
Hey, I learned something new today, cool. I'm spoiled because our 50 and 900EX have DEECS. Push it too the stop.
Hugh Johnson When's the last time you took an airline flight where the crew made a static takeoff? QUOTE said:
We used to run the power all the way up at SNA (John Wayne/Orange County CA) and then release the brakes - all part of the company noise abatement profile.
On the original poster's question:
I have found that FO's that have been yelled at for overboosting the power beyound target are worried about doing it again. If I had a guy doing that I would say, "Have it up to at least the target N1 by 80 knots, if it's 1 percent over that's okay as long as the EGT is within limits."
My favortie is when a parameter creeps into the yellow during a takeoff and somebody feels the need to snatch the respective power lever back into the green range. Apparently forgetting entirely that the yellow arc on this aircraft denotes a 5 MINUTE (!) limitation for takeoff.
