FL420
Blues vs. Birds-Tailhook
- Oct 11, 2005
What the IFIM says:
It's getting pretty bad when I start quoting myself.
I looked in my six-year-old company International Operations Manual which stated air-to-air communications should be conducted on 131.8 MHz in the Atlantic, 130.55 MHz in the Caribbean and 128.95 MHz in the Pacific. I then looked in the current International Flight Information Manual which states 123.45 MHz should be used in the Atlantic, Caribbean and Pacific Oceanic Areas.
FL420 said:It is my understanding 123.45 was established for use in Oceanic Areas for crews to coordinate separation during weather diversions and emergency procedures in RVSM airspace.
:bawling: :smash:http://www.faa.gov/ats/aat/ifim/ifim0111.htm
International Flight Information Manual, The Federal Aviation Administration
Basic Oceanic Long-Range Navigation and Communication Requirements
a. Any operation which is conducted in international oceanic airspace on an IFR flight plan, a VFR controlled flight plan, or at night, and is continued beyond the published range of normal airways navigation facilities (NDB, VOR/DME), is considered to be a long-range Class II navigation operation…………
b. Federal Aviation Regulation 14 CFR Part 91.1(b) requires that civil aircraft must comply with ICAO Annex 2 when operating over the high seas…………
Use of Very High Frequency (VHF) and High Frequency (HF) for Communications
Due to the inherent line of sight limitations of VHF radio equipment when used for communications in international oceanic airspace, those aircraft operating on an IFR or controlled VFR flight plan beyond the communications capability of VHF will be required, as per ICAO, Annex 2, to maintain a continuous listening watch and communications capability on the assigned HF frequencies. Although these frequencies will be designated by Air Traffic Control, actual communication will be with general purpose communication facilities such as international flight service stations or Aeronautical Radio, Inc. (ARINC). These facilities will be responsible for the relay of position reports and other pertinent information between the aircraft and Air Traffic Control.
Special North Atlantic, Caribbean, and Pacific Area Communications
a. VHF air-to-air frequencies enable aircraft engaged on flights over remote and oceanic areas out of range of VHF ground stations to exchange necessary operational information and to facilitate the resolution of operational problems.
b. Frequencies have been designated as follows:
AREA
FREQUENCY
North Atlantic
123.45 MHz
Caribbean
123.45 MHz
Pacific
123.45 MHz
Guard of VHF Emergency Frequence
Pilots should remember that there is a need to continuously guard the VHF emergency frequency 121.5 MHz when on long over-water flights, except when communications on other VHF channels, equipment limitations, or cockpit duties prevent simultaneous guarding of two channels. Guarding of 121.5 MHz is particularly critical when operating in proximity to flight information region (FIR) boundaries; for example, on Route R220 between Anchorage and Tokyo, since it serves to facilitate communications with regard to aircraft which may experience in-flight emergencies, communications, or navigational difficulties.
REFERENCE- ICAO Annex 10, Vol. II, Paragraphs 5.2.2.1.1.1 and 5.2.2.1.1.2
