Here at ASA, most Captains will tell you to switch to V/S at the slightest bit of oscillation. Heard that gets hammered out when they head to mainline, where I believe most legacies prohibit V/S climb
You heard wrong.
The CRJ is not meant to go much above 280 -310.... Pushing it up to 340 (or as the PNCL guys did) max alt. is a very risky plan... Unless empty with min fuel, it just isn't powerful enough. Period....
Probably just a thousand pounds per hour of fuel.Lemme tell ya for those that want the badge of honor, there is no real difference between cruising around at 280 or 380....
I preffer Speed Mode in a climb, with Turb. mode engaged. Works like a champ. Only need to be on the lookout in the mid 20s for a climb rate less than 500fpm. Its more accurate and precise than fumbling V/S mode all the way through the climb, while flying a fluctuating climb speed of +/- 10 knots.
Just got refiled today for a pack deferral.....difference between FL 330 and 250 was 140lbs. That's it......about $70 of fuel that UA, DL, AA pays anyway. That's it! Altitude in the CRJ200 is almost immaterial. Why bother???
Because being dead on the bucket for some random, arbitrary climb speed is more important than passenger comfort.
I notice them both when in the back.
