DC8 Flyer said:Explain the fluid coupling. Im an engine mechanic idiot.
DC8 Flyer said:So it almost works like a free turbine on a turboprop, except it uses engine oil instead of low pressure air to turn the "turbine"?
USMCmech said:These systems were used on many WW2 aircraft, mainly bombers.
A Squared said:I can't think of a single WWII aircraft which had Turbocompound (PRT) engines. The Turbocompound engines were a later development. I believe that the only production Turbocompound engine was the R-3350 (the R-3350's on the B-29 were not turbocompound) The R-3350TC powered post war, pre-jet era aircraft such as the C-119, Super constellation, DC-7, P2V Neptune. Allison developed a turbocompound version of the V-1710 The V-1710 TC was intended to be used in a version of the Bell Kingcobra, which was cancelled. Pratt & Whitney developed aversions of the R-4360 which was sometimes referred to as a turbocompound, although it was actually using a varaable nozzle on the turbocharger to maximize jet thrust from the exhaust. THis enginewas to be used in the B-50C and b-36C. Both models were cancelled before production. Avbug can chime in here if I'm wrong, but I don't think that the KC-97 ever had the Turbocompound version of the 4360 installed.
-Less 'sucking' by the engine because RPMs have decreased so the engine can't take as much air IN.#1. During a run-up, why does manifold pressure increases when RPM is dropped...
-Less restriction to 'sucking' by the engine because the butterfly's opening up and allowing more air IN.#2 Why at cruise does manifold pressure rise when you increase the throttle but don't touch the prop lever?
-Yes. (IF the throttle plate is not all the way open already)#3. At crusie power (not low power like in a run-up)... if you reduce rpm by pulling back on the prop lever does manifold pressure still rise?
-The governor can only do so much. After it's reached its low-pitch (high-RPM) stop, it can't control the RPM anymore. The amount of power the engine's putting out does. As to manifold pressure, the answer's the same as #2. The throttle still varies how much air is available to the engine, and how hard the engine has to 'suck' to get it. (throttle plate position in the intake tract)#4. And I can't help it but I'd like to know if you agree on why during low rpms on the ground does the throttle control RPM and manifold pressure. With props full forward we are able to add the throttle and increase the RPM to approx 17-18 hundred RPM... but at higher throttle settings RPM is controlled by the prop / governor.
Bernoulli said:#1. During a run-up, why does manifold pressure increases when RPM is dropped...
#2 Why at cruise does manifold pressure rise when you increase the throttle but don't touch the prop lever and...
