DC8 Flyer said:Almost. Remember when we lower the RPM we lower the rate at which the mass of air enters the cylinder (2700 RPM - 45 times a second 2200 RPM = 33 times a second). We dont change the mass we simply change how many times it enters the cylinder over a given time period. Since Horsepower is work over time, the lower the rate at which the fuel is burned lowers the work over time equation. So we are changing power, otherwise we could take off at 2200 RPM and have the same power as 2700 RPM.
Just keep in mind I am talking about the same airplane at the same point in space and time just one instance is 2700 RPM and the other is 2200 RPM, throttle and mixtures are the same only difference is RPM by prop control.
DC8 Flyer said:Nope, sorry. All the MP gauge measures is absolute pressure at the intake valve (thats where the sensor is). If the engine is windmilling, ie no power, there is a very slow rate of "suction" thus the largely scaled MP gauge would read atmospheric pressure (absolute pressure in this case).
You guys need to get off this idea that just because the engine sucks air in, that it is creating a vacuum, if that where true the engine would be starving itself because in a vacuum there is no air.
The intake manifold doesn't care whether the engine's 'running' or 'windmilling', just that it's 'pumping'.DC8 Flyer said:You two are talking about two different phenomena, engine running, engine windmilling. The windmilling engine rise and fall in MP is due to expansion since the velocity of the air through the manifold is very slow 300 to 400 RPM.
Doesn't the volume of air entering the intake manifold decrease in proportion to the RPM change, minimizing any velocity change? It IS a positive-displacement pump, after all.DC8 Flyer said:Now lets get back to the OP's original topic. Why does MP rise when he does a prop control check on runnup. Because with the throttle plate fixed as the air pump (piston) slows down the speed at which the volume of air is moving through the manifold decreases, raising its pressure.
AvBug, you really need to stop and think about what you are saying and read a book. Just because something sucks air in, doesnt mean it lowers the pressure entering or raises just because its a pump, there are Physics laws for the changes in pressure and you as a pilot should know them. I've given you multiple examples, formulas, Fluid Dynamics laws, its your turn to come with something other than "I said so". Anyone who flys an airplane with variable pitched props and a manifold pressure gauge know as you pull the props back the MP rises, there is only one way to describe it, and its not because the engine is a vacuum cleaner sucking air, therefore the pressure rises because the engine isnt sucking as hard. What does that explain? Look at a vacuum system and how it works, given suction to maintain an airstream velocity. Same as your precious vacuum cleaner analogy but pressure falls as engine speed is increased so it is vented overboard.
Just because the piston is sucking doesnt mean its creating a vacuum, the volume beind displaced is being filled with air at a restricted rate. This rate is slow enough to that not enough of ambient pressure air can fill the cylinder so the air that does get in expands to fill its container, and keeping with thermodynamic and fluid dynamic laws, the pressure decreases.
DC8 Flyer said:I am by no means calling you dumb, you know more about engines than I ever could. The point I am trying to make, is that just because the piston is going down and drawing air in that doesnt make the pressure go down. The pressure goes down BECAUSE the air is traveling faster through the manifold. You could blow air into the manifold and get the same result. Take the manifold off the cylinder and blow air through from the intake end you will see a drop in MP because of the bernoulli effect.
The faster the piston moves down the faster the air is drawn through the manifold, we agree on this I think. Just take it the step further and apply the laws of physics to what happens to a fluid as its velocity is increased.
If the piston was making a vacuum you would see zero on the MP gauge, no air in a vacuum. The piston is displacing volume causing a pressure differential. Maybe thats being too nit picky on word usage but it seems the idea is that just because the piston goes down, it creates a void and pressure drops, when that is not what is happening when we just pull the props back.
MVSW said:This is a really funny post. I was reading this and I read about 25 different reasons why MP goes down when you decrease RPM!!LOL
flyifrvfr said:Can someone please tell me why manifold pressure increases when you decrease RPM'S when you are doing a run-up
Donsa320 said:Yes. You are pulling air out of the intake manifold into the cylinders at a slower rate as the RPM decreases so air coming in over the throttle plate from the atmosphere can increase the Manifold pressure closer to ambient.
Do you like it? (grin)
