USMCmech
- Jan 7, 2005
DC8 Flyer said:Clamping my hand over the hose is the same as closing the throttle plate, which the OP was not doing. He is asking about MP rise due to RPM reduction. Keep in mind I am talking about a carb system not fuel injected.
Carb or fuel injected there is no difference.
If I cover the end of a vaccum cleaner the pressure drops because it becomes a vaccum, all the air is sucked out. Thats not what happens when you move the prop levers to a lower RPM, you simply slow the velocity of the air down as it is entering the manifold
Reduceing the RPM by changine the pitch of the prop would be equivilant to reduceing the speed of the vaccum cleaner motor in the above scenerio.
Since there is less suction, the pressure in the hose rises.
