Manifold Pressure Question
DC8 Flyer said:
I am by no means calling you dumb, you know more about engines than I ever could. The point I am trying to make, is that just because the piston is going down and drawing air in that doesnt make the pressure go down. The pressure goes down BECAUSE the air is traveling faster through the manifold. You could blow air into the manifold and get the same result. Take the manifold off the cylinder and blow air through from the intake end you will see a drop in MP because of the bernoulli effect.
The faster the piston moves down the faster the air is drawn through the manifold, we agree on this I think. Just take it the step further and apply the laws of physics to what happens to a fluid as its velocity is increased.
If the piston was making a vacuum you would see zero on the MP gauge, no air in a vacuum. The piston is displacing volume causing a pressure differential. Maybe thats being too nit picky on word usage but it seems the idea is that just because the piston goes down, it creates a void and pressure drops, when that is not what is happening when we just pull the props back.
Lordy, I see you guys are still at it. USMC just did a good summary and DC-8 it looks like you have come around a little.
Now it looks like DC-8 has gradually accepted that the engine is just an air pump and MAP is not dependant on the engine even operating. MAP (Manifold Air Pressure) is dependant upon the position of the throttle plate and the RPM of the engine, whether it is windmilling or operating.
Some examples: In flight, at a high enough cruise speed that the constant speed propeller can maintain the set RPM, move the mixture to cut-off. Observe the MAP. There will be NO change if the RPM does not change. Lesson; Manifold Air Pressure is NOT am indicator of engine power. Lesson 2; RPM is not an indicator of engine power either. I point these facts out to light-twin engine pilots especially.
Next, at lower airspeed where the RPM may decrease on a failed engine, one may see the MAP actually increase on the non operating engine. Again a misleading indicator of power loss or failure leading to misidentification of the failed engine.
These are some practical applications of the indications we are talking about.
The MAP rise during the propeller governor check or when reducing RPM during power reductions from Take-Off to Climb or from Climb to Cruise help illustrate this.
That otta get ya going again! <bg>
~DC
So what about the volume change? If you reduce the RPM from 20%, the volume of air being drawn into the engine for any given amount of time decreases 20%, wouldn't it?
We're not talking about cylinder pressure though, we're talking manifold pressure.
With a 7.5% decrease in RPM, don't you get a 7.5% decrease in the volume of air pulled through the intake manifold if the throttle plate doesn't move?
(OK, I realize that air's actually 'pushed' through the intake manifold due to the differential pressure caused by the increased displacement in all 6 cylinders on their intake strokes.)
And the intake manifold doesn't know whether the engine's running or not, just that air's being transferred through it.
This is a really funny post. I was reading this and I read about 25 different reasons why MP goes down when you decrease RPM!!LOL
Now, that is sad.....because MAP goes UP with a decrease in RPM, that was what all this was about. <vbg> Shows you what complicated explanations can do.
~DC
Correct Again! But only if you are only using one or the other, the two combined tell you engine power;
DC-8
My last word on the subject...you are WRONG again. You can have Manifold Pressure and RPM and NO power, they are both INDIRECT indicators of power, whether alone or together. Any windmilling engine will show you this. Please, get out and fly and try it out, Jeez! You do fly do you not? You claim an ATP but I guess it was not in piston power. These facts are true in both normally aspirated and geared supercharger engines. From Apaches to DC-3s, Convairs and bigger. From O-320s to R-4360s and R3350s, I have plenty of time with all of them.
When you get to Turbo Superchargers there is a difference since exhaust energy is required to get some boost. If you want to go there, do it with someone else.
Good Day Sir.
flyifrvfr said:
Can someone please tell me why manifold pressure increases when you decrease RPM'S when you are doing a run-up
Yes. You are pulling air out of the intake manifold into the cylinders at a slower rate as the RPM decreases so air coming in over the throttle plate from the atmosphere can increase the Manifold pressure closer to ambient.
Do you like it? (grin)
Prt
Donsa, I know you bowed out of this conversation, However a quick ??
In the large engines you mentioned, I recall Power Recovery Turbines or some such from my A&P books. Only having seen them in museums, I forget how they work, Maybe you guys can explain them...they were/are pretty neat...
You are still not explaining it! You said it "You are pulling air out of the intake manifold into the cylinders at a slower rate". What law jumps out at that statement?
