What's the difference between being "furloughed" as a probationary pilot with no recall rights like USAir is doing starting this fall, and being terminated or fired.
Because AirTran's furlough language is different? Not sure what you're saying about USAirways is even true (that they don't have recall rights), but AAI's furlough language retains recall rights for both non-probation and probationary pilots alike.
The word "fired" gets thrown around quite a lot when people get laid off or separated through no fault of their own. That shouldn't be considered getting fired.
I've never seen that kind of generalization made about furloughed pilots. Everyone in the world understands the term "laid off". It's going to be a sticky point on their job applications going forward: "Were you ever terminated from a job before?" "Yes, but it was more of a furlough because they needed to downsize, even though it will show up as a termination and, ummm..." And that's if you're lucky. Netjets and XOJet both have that question on the Application, so you never even get to explain what happened, as you never make it past initial selection.
Would really suck for these F/O's IF the company stoops that low...
It had little to do with the bent of the judge and everything to do with the skill of the lawyers. Is Airtran in Section 6 and if so was notice thereof served on the company?
Yes and yes.
AirTran has been in Section 6 negotiations (on and off) for several years. Furlough notices are required 60 days out per the Contract (much further in advance than the WARN act provides for).
That's why everyone's waiting for the end of the month - if they want to reduce man power along with the block hour reduction effective September 1st, they're going to have to put the notice out around that time period to comply.
If I had to bet, they'll put a notice out for several hundred people just to scare the crap out of everyone right before the Negotiating Committee heads up to D.C. for renewed talks where they will likely ask for concessions in exchange for retaining jobs.
Personally, I don't see how they can cut any more than 50 pilots and still have enough people to cover the holiday schedule (if it ramps back up as usual over Sept and Oct flying).
It's nothing but a game of "see who blinks first" to them; we're a number, nothing more. Sad, really...
