HS125
- Feb 5, 2002
Lead Sled said:I haven't seen the APG procedure. (Anyone have a website?) IMHO, you should always try any alternate procedure in the airplane prior to betting your a$$ on it. For some of you it may be difficult - you don't get there all that often. If you have the opportunity (and the weather allows it) just coordinate with ATC and let them know what you want to do. The time to try and figure out that the procedure is telling you to do isn't immediately after shutting one down and you are up to your eyebrows in airplane. The ideal way to handle the situation is to have it standing at the ready in the #2 FMS. (Using a "pilot" SID.) Prior to departure brief you simply review the procedure for the PNF to bring it up for you should the need arise. It's very simple and straight forward.
'Sled
The APG weights and special departure procedures are provided by Airinc Direct through a subscription service to Airinc Direct. Most of the procedures that I have seen and used are simple enough and often follow the normal DP's for the given airport, making for an easy transition in the event of an engine failure.
Another thing to keep in mind when using a special engine out departure procedure; If you depart on the normal DP and subsequently have an engine failure after you are airborne, can you safely divert from the normal DP and get established on the escape procedure that you have base your takeoff weight on?
Try planning on using the 280 heading procedure out of KEGE so that you can carry the weight to get home, and then departing on the Gypsum DP. If you lose an engine after you are airborne on the Gypsum 215 heading, I'd bet my paycheck that you can't safely make a right turn to get to get established on the 280 heading without flying into the hill off of Rwy 25. And if you used the higher weights based on the 280 heading departure, you wont be garunteed terain clearance flying out on the Gypsum DP which requires a lower weight. Gotta use your head out there.
