LIFR in a Piston Single
I hear ya...although I'm not so sure how well you can identify truly suitable landing sites at night. One advantage of New England, is that if you do lose an engine at 7000, you have a decent chance of finding an airfield within gliding distance, but other than than much of the area outside of the cities is a mixture of trees and fields which at night, you really can't tell the difference until your landing light illuminates the trees in front of you.
Fearless Tower said:
One advantage of New England, is that if you do lose an engine at 7000, you have a decent chance of finding an airfield within gliding distance, but other than than much of the area outside of the cities is a mixture of trees and fields which at night.
Mostly trees. And I see your point as well. One can never completely escape risk.
-Goose
I used to fly piston singles at night in low IFR quite a bit at a previous job. At first it didn't seem like a big deal, but the more I did it, the more uneasy I felt. For me I think it was the idea of the law of averages that made me nervous. The more I did it, the more of a chance for a failure of some sort, engine or otherwise. Sure enough, I eventually had a vacuum pump failure with no standby. Fortunately the wx wasn't very low and I continued to my destination using the turn coordinator. One of my fellow pilots at that company lost a vacuum pump while I was there and had to do an approach to near minimums with just the turn coordinator. I'm glad I don't have to do that anymore. Now I fly an airplane with two turbine engines. I'm more comfortable flying at night and in low IFR with this airplane, but I still feel far from invinceable. Just like was mentioned already, it all comes down to risk management. All flying involves risk. Some flying, much more than others. The important thing is to know what the risks are and be prepared as much as possible when something does go wrong.
I agree with a sentiment that's been mentioned a few times on here... I don't worry so much about the engine, I'm more concerned with one alternator and one vacuum pump. Those two things alone would concern me. Most higher-performance single have built in redundancy with those systems that would make it more palatable (sp) for me to tackle LIFR - single engine.
Can you please expand on that? I've heard it from others too, and it doesn't make much sense to me. Without vacuum or electric, the plane flies just fine and you have options open. Without engine power, your ass is toast and there isn't a thing you can do about it.
Obviously I'm not yet qualified to make blanket statements about this topic, but I just can't help but surmise that without a healthy ceiling, I'd rather lose my vac pump or alternator than my engine, 10 times out of 10.
So... set me straight if I'm wrong.
In my opinion, an alternator and vacuum pump are parts that are expected to wear and fail or go bad over time and odds are they will quit in flight. Not having a redundant system or backup leaves many pilots that fly these planes in LIFR to feel that it is just a matter of time before it is "their" turn.
Engines on the other hand "in theory" can run indefinitely when properly maintained. Poor maint, abuse and defective parts account for a large majority of engine failures.
I agree with you. The plane will fly just fine on the "backups" as long as your are proficient. But if you are not proficient on "partial panel" and the ceilings are really low, the plane will fly just fine as you get disoriented and fly it into the ground. And once again, I'll fly an airplane that has the basic TOMATOFLAMES all day long in VFR. But low IFR is a whole new ball game. And to make it a long ways in your career, it all depends on risk management. For me personally, I don't take low-performance single engine (no redundant systems) into low IFR.
Why would you be flying in IMC conditions and not be proficient at partial panel? That shouldn't even be considered a risk. That's like saying it's a high risk flying a retractable gear airplane because you're not proficient at using the checklist and have a hard time remembering to put the gear down. These things are basic knowledge every pilot should have.
... you really can't tell the difference until your landing light illuminates the trees in front of you.
Which makes the "Off" feature of the switch, a nice thing.
How proficient are you at parallel parking? Probably not very much unless you happen to do it on a regular basis.
During primary instrument training PP is drilled into you and becomes almost second nature. However it is entirely unrealistic to expect someone to retain the razor edge on their PP skills if they don't routinely 1. experience or 2. practice such things. It shouldn't be "hard" for an instrument proficient pilot to keep wings level using a TC, but once adrenaline and/or panic kicks in during an emergency it can be difficult to revert to unused skills.
Having "Basic knowledge every pilot should have" is not the same as maintaining partial panel skills that atrophy after disuse.
You are right about skills atrophying after disuse. I'm not sure how often you take some sort of instrument proficiency check, if it's part 135 or 121 it is at least every 6 months. If you just fly in your leisure (boy that sounds like fun), the same time frame applies. If you feel deficient then do some partial panel on every instrument check, that should keep you up to speed. As far as the parallel parking goes, I always thought that was kind of like riding a bike. But seriously, I don't think anyone giving you a checkride or other instrument proficiency check would have a problem with you requesting to do some partial panel.
When I was an instructor I did a few of those flights. What the weather is crappy? Time to build some experience!
I only did a few of those flights but I still remember them. Solo IFR in a single was a tremendous learning experience not to mention it is very satisfying. The only reason I would not do it today is because my partial panel proficiency is in the crapper.
Yes, there is risk involved as with anything. But the question is. Are you prepared to accept those risks? And if it comes down to it. Can you manage those risks if the time comes to?
Wankel
