Dangerkitty
- Feb 21, 2004
ERJ-140 said:Whatever dude. I know exactly what a shadow is. And I am telling you that you have NO IDEA HOW THE EMB RADAR WORKS. PERIOD. If you have an area of ground clutter or rainfall that extends beyond your "shadow" area then you know you are painting a cell. You can manipulate what the radar shows you by adjusting gain. YOU CAN PAINT "NOISE" WITH THE ANTENNA POINTED UP 15 DEGREES BY MANUALLY PUTTING THE GAIN TO MAX! THERE IS NO REQUIREMENT FOR PRECIP FOR THE RADAR TO SHOW NOISE. YOU CAN TELL A RETURN IS REALLY RAIN BY FORCING IT TO ATTENUATE AT A LOWER POWER SETTING THROUGH THE GAIN. I WILL QUOTE THE AOM FOR YOU AGAIN SINCE YOU COULDN'T READ IT THE FIRST TIME:
"NAVIGATION AND
COMMUNICATION
AIRPLANE
OPERATIONS
MANUAL
2-18-45
Page
12
Code
01 REVISION 6
ANTENNA STABILIZATION (STAB or STB)
The antenna is normally pitch and roll-stabilized by using attitude
information from the IRS. Momentarily pushing the STAB (or STB)
button disables antenna stabilization and an amber “STAB”
annunciation label is presented on the PFDs’ and MFDs’ radar mode
field.
RECEIVER GAIN (GAIN)
The GAIN knob is a rotary control and push/pull switch that controls
radar receiver gain. Two gain modes are available: calibrated or
variable.
Calibrated: When the GAIN knob is pushed in, receiver gain is preset
and calibrated, which is the normal mode of operation. In calibrated
gain, the rotary function of the GAIN knob is disabled.
Variable (VAR): When the GAIN knob is pulled out, the system enters
the variable gain mode. Variable gain is used for additional weather
analysis and for ground mapping. In the WX mode, variable gain can
increase receiver sensitivity over the calibrated level to show very weak
targets or can be reduced below the calibrated level to eliminate weak
returns. In the GMAP mode, variable gain is used to reduce the level of
strong returns from ground targets."
CALL IT A SHADOW. CALL IT A RETURN. CALL IT A DEADSPOT. CALL IT WHATEVER THE HELL YOU WANT. THIS IS WHAT PEOPLE REFER TO WHEN THEY ARE TALKING ABOUT PULLING A SHADOW OUT OF A RETURN. THIS IS HOW YOU DISTINGUISH PRECIP FROM CLUTTER!!!!!!!!!! If you are painting everywhere to 100 miles and in one spot only paint to 75 miles then you are probably seeing a cell. This is an X-band radar if I am right so it will attenuate fairly easily. The gain helps you interpret what it is telling you. Leaving it in AUTO will give you either all black, all green, a green egg for an area of heavy rain when you get close to it, or all green, red, yellow. The GAIN helps you determine what you are or are NOT seeing and helps you do so at greater range than leaving everything in AUTO.
Geeeeeze.....amazing what a lunkhead you are acting like over phraseology. I have asked you to correct the terminology and all you do is call me names. I am really trying to explain this in intuitive terms and it just isn't sinking in. Well, I may be a fraud but I can spot weather with an EMB radar better than you can obviously.
If you can't keep a civil tone then please go discuss this topic with the voices in your head.
The concept of a radar shadow is not an abstract conept. It has nothing to do with ground clutter. I have explained this over and over and over and you still don't get it. Then I give you a verbatim definition and you still dont understand it. Furthermore, you go off on the tangent about using the gain. Messing with the gain will do nothing when it comes to a radar shadow. Using the tilt might help a little but the gain will do nothing for you.
When you are messing with the gain all you are doing is changing the sensitivity of the radar. With a radar shadow (as I have explained countless time) the attenuation is so strong that the radar cannot tell you what is on the other side of the very strong precip. Changing the gain is not going to get the signal through that attenutation area. It can't be done.
You have got to be the biggest moron of all time to ever come the flightinfo. And after reading some of the posts here for a few years that really is saying alot.
You are such and idiot that you have no clue what a dumba$$ you sound like.
I have tried to explain a simple concept over and over and over to you and you still dont get it. Maybe someone else out there could explain what a radar shadow is to this ignorant douche bag?
Oh by the way ERJ-140 I am still curious about your job interview. You know from all those PM's yo got the night you were $hitfaced and made a fool out of yourself posting all those rambling messages.
How did it go?
