Fedora
- Jan 15, 2007
It's always a tough decision and always a personal one for each of us. We don't know your situation or desires, so it's tough to get advice from out here. The economy can change at the drop of a bomb. Companies start to furlough, etc. AT has cash to last a while and you're not at the bottom of the list. CA has oportunities if thing continue to go well.
My wife and I have a plan when we get to these crossroads. Take a piece of paper and draw a line down the middle. Label each collumn with the airlines in question. Divide those two columns into a pro and a con list. Write down what each of you percieve as the good and the bad things for each company. when done, cross out the ones that cancell each other out for both companies, then compare the plusses and the minusses. You are sometimes surprised at the results, but if nothing else, it will bring out the things that are IMPORTANT TO YOU!
It sounds like the commute thing is a primo factor from what I've read so far. Congrats on the baby and good luck in whatever you choose for your future. I used to work at AT and would be about 25 on the seniority list if I had stayed, making a lot more money than I do now. That said, I love being an international wide body Captain and don't see 4 on and 3 off as a good schedule any more. QOL should be an issue too!
Good luck!
Good luck!
