Because neither your OpSpecs nor your GOM define the regulation. The definition for the regulation is found in 14 CFR Part 1.
"Precision or non-precision.Because neither your OpSpecs nor your GOM define the regulation. The definition for the regulation is found in 14 CFR Part 1.
What your GOM has to say is entirely irrelevant.
Bug is it a precision approach?
I don't suspect he is going to respond anymore which is disappointing.
This has already been answered, earlier in the thread, with specific changes to the regulation applicable to the question. Ergo, read the thread.
The AIM does provide a definition that has been given. Until recently, any approach with a glideslope was precision. The LDA with a glideslope contrary to popular belief, was a precision approach. It is now considered "precision-like" due to an expansion in the definition.
Paul, here's the reply from earlier:
The AIM while guidance is not specifically regulatory and I wouldn't base a regulatory decision off it. Nothing has changed in the FAR's in regard to LPV/LDA, the wording in the AIM has changed but that isn't specifically legally binding (though it does further support the concept that only a ILS/MLS/PAR are precision approaches).
Precision approach procedure means a standard instrument approach procedure in which an electronic glide slope is provided, such as ILS and PAR.
7. TERPS criteria are provided for the following types of instrument approach procedures:
(a) Precision Approach (PA). An instrument approach based on a navigation system that provides course and glidepath deviation information meeting the precision standards of ICAO Annex 10. For example, PAR, ILS, and GLS are precision approaches.
(b) Approach with Vertical Guidance (APV). An instrument approach based on a navigation system that is not required to meet the precision approach standards of ICAO Annex 10 but provides course and glidepath deviation information. For example, Baro-VNAV, LDA with glidepath, LNAV/VNAV and LPV are APV approaches.
(c) Nonprecision Approach (NPA). An instrument approach based on a navigation system which provides course deviation information, but no glidepath deviation information. For example, VOR, NDB and LNAV. As noted in subparagraph i, Vertical Descent Angle (VDA) on Nonprecision Approaches, some approach procedures may provide a Vertical Descent Angle as an aid in flying a stabilized approach, without requiring its use in order to fly the procedure. This does not make the approach an APV procedure, since it must still be flown to an MDA and has not been evaluated with a glidepath.
Again, the information has already been covered and provided in enough scope and detail that as stated before, no further response should be necessary. All the "I think it should mean" or "it ought to say" in the world doesn't change what's provided, and what's provided is clear enough.
Your right I should have been more clear in my resposne. An LDA with a G/S has never been considered a precision approach by the FAA.
