LDA w/Glideslope
JettBoii
Precision or non-precision.
Op Spec C072 says it is a non precision for air carriers. It is a precision like non precision approach.
What about for 135/91?
I think it is a NP, and my reasoning, is I would have to maneuver the aircraft from the LDA course to align with the runway.....only my opinion
In FAA ultra-confusing-legalese terminology, it is considered a non-precision approach with vertical guidance.
AIM 5-4-5
(a) Precision Approach (PA). An instrument approach based on a navigation system that provides course and glidepath deviation information meeting the precision standards of ICAO Annex 10. For example, PAR, ILS, and GLS are precision approaches.
(b) Approach with Vertical Guidance (APV). An instrument approach based on a navigation system that is not required to meet the precision approach standards of ICAO Annex 10 but provides course and glidepath deviation information. For example, Baro-VNAV, LDA with glidepath, LNAV/VNAV and LPV are APV approaches.
(c) Nonprecision Approach (NPA). An instrument approach based on a navigation system which provides course deviation information, but no glidepath deviation information. For example, VOR, NDB and LNAV. As noted in subparagraph h, Vertical Descent Angle (VDA) on Nonprecision Approaches, some approach procedures may provide a Vertical Descent Angle as an aid in flying a stabilized approach, without requiring its use in order to fly the procedure. This does not make the approach an APV procedure, since it must still be flown to an MDA and has not been evaluated with a glidepath.
So it's really neither. It's an APV (approach with vertical
Guidance. There are now 3 categories.
For what it's worth my company logs LDA's the same as an ILS. Perhaps this is due to the vertical guidance that is provided, perhaps this is due to the fact that the B.A.R.T. software that we use for crew and aircraft activity logs considers them the same.
I checked my company FOM and it is considered a "precision like non-precision aproach".
Going with non-precision.
Thanks Guys
LDA/GS is definately a non-precision approach.
Far 1.1:
Precision approach procedure means a standard instrument approach procedure in which an electronic glide slope is provided, such as ILS and PAR.
But the AIM defining it as Approach with vertical guidance (APV).
But Opps specs define it as a non-precision.
Our op specs call it a precision like approach
I missed the 1.1 but just read it and it does say that a precision approach has a glideslope "like a ILS or PAR". The definition if a non precision is one that has no glide slope; the LDA/GS of course does.
What would you say on an interview?
The LDA is of comparable utility and accuracy to a localizer but is not always aligned with the centerline of the runway. Terps requires the localizer signal alignment with 3 degrees of the runway alignment. If the alignment exceeds 3 degrees, the localizer will be identified as an LDA.
Once designated as an LDA, the max angle of convergence of the final approach course and the extended runway centerline is 30 degrees. The signal accuracy of the LDA is the same as a Localizer, however the LDA course alignment will be greater than 3 degrees, not to exceed 30 degrees. Straight-in minima can be published only where alignment conforms to the straight-in criteria. Circling minima are published where this alignment exceeds straight-in criteria.
The LDA is usually considered a non-precision approach; however, in some installations with a glide slope, a decision height will be published. If a decision height is published, it can be flown just like an ILS approach.
1-1-9 C) #3 - LDA/Glideslope falls under the APV category (approach with vertical guidance).
5-4-5 7.(b) - APV approaches based on a navigation system that is NOT required to meet the precision approach standards of ICAO annex 10.
If you have to manuver to join final, can it really be precision?
That's really irrelevant, but to reply, yes. ILS approaches frequently require maneuvering to join the final approach course, too.
What your OpSpecs say is also irrelevant. OpSpecs do not define the regulation, and only apply to your company operations.
The AIM does provide a definition that has been given. Until recently, any approach with a glideslope was precision. The LDA with a glideslope contrary to popular belief, was a precision approach. It is now considered "precision-like" due to an expansion in the definition.
Perhaps it has been changed, but I affirmatively recall reading in the AIM a long while ago that the LDA/GS is NOT considered a precision approach.
Where this has become relevant from my perspective is that WAAS allows for GPS only airports to be alternates. So if you are part 91 it makes a difference as to which it is for alternate minimums (600/2 or 800/2).
AIM 1-1-20
(a) Due to initial system limitation, there are certain restrictions on WAAS operations. Pilots may plan to use any instrument approach authorized for use with WAAS avionics at a required alternate. However, when using WAAS at an alternate airport, flight planning must be based on flying the RNAV (GPS) LNAV minima line, or minima on a GPS approach procedure, or conventional approach procedure with "or GPS" in the title. Code of Federal Regulation (CFR) Part 91 nonprecision weather requirements must be used for planning. Upon arrival at an alternate, when the WAAS navigation system indicates that LNAV/VNAV or LPV service is available, then vertical guidance may be used to complete the approach using the displayed level of service. The FAA has begun removing the
NA (Alternate Minimums Not Authorized) symbol from select RNAV (GPS) and GPS approach procedures so they may be used by approach approved WAAS receivers at alternate airports. Some approach procedures will still require the
NA for other reasons, such as no weather reporting, so it cannot be removed from all procedures. Since every procedure must be individually evaluated, removal of the
NA from RNAV (GPS) and GPS procedures will take some time.
So whatever it is classified as it would seem to indicate that it needs to be considered as non-precision for planning purposes.
WAAS has nothing to do with an LDA approach with a glideslope. What are you talking about?
No but whether a LDA approach with a glide slope is precision or non-precision is necessary to know to determine if an airports weather is suitable for use as an alternate. This is especially true when the airport is only served by a GPS approach (which WAAS allows for).
I can't really think of any other reason why you would care if it is precision or non-precision (aside from taking the requirements of the instrument PTS). The relevant AIM section shows that for alternate planning you consider non-precision which means 800/2.
It's a common inteview question.
To which there is no definitive answer, but it is also a practical concern which if somebody isn't sure of the answer could cause them a problem.
Precision approaches also I will add to the discussion require precision markings on the runways and specific lighting. I don't believe that any of the GPS approaches require any special markings or lighting.
No, there certainly is a difinitive answer, and it's already been provided. What there is not is room for discussion or debate; the matter is clear.
I disagree bug. FAR 1.1 gives one answer. The AIM gives another answer, and 121 OpSpecs give a 3rd answer.
Operations specifications are irrelevant, as previously discussed. They do not define the regulation.
14 CFR 1.1 and the AIM don't disagree. The AIM merely clarifies the definition as provided in Part 1.1.
For the purposes of the regulation, 1.1 is difinitive and applicable. This includes the application of regulation pertaining to the selection of an alternate, etc. The AIM serves to expand on that, but in no case replaces the regulation, nor is the AIM regulatory in any respect.
What one's operations specifications, general operations manual, fortune cookie card, horoscope, or underwear label has to say does not replace the regulation, count for regulation, or change what is stated in the regulation.
So you agree that 1.1 defines it as a precision approach? And that the AIM lists it as a APV?
We will just agree to disagree on that. The only matter of relevance for precision/non-precision is flight planning and in that regard it counts clearly as non-precision (or do you debate that as well).
Op Spec C52 Inst Approach with Vertical Guidance (APV) other than ILS or MLS
LDA/w GS, LDA PRM, LDA PRM DME; SDF/w GS, LOC BC/w GS
How come?
Once again for those just tuning in...the opspec is irrelevant.
Why is anything in my GOM irrelevant?
