Because neither your OpSpecs nor your GOM define the regulation. The definition for the regulation is found in 14 CFR Part 1.
"Precision or non-precision.Because neither your OpSpecs nor your GOM define the regulation. The definition for the regulation is found in 14 CFR Part 1.
What your GOM has to say is entirely irrelevant.
Bug is it a precision approach?
I don't suspect he is going to respond anymore which is disappointing.
This has already been answered, earlier in the thread, with specific changes to the regulation applicable to the question. Ergo, read the thread.
The AIM does provide a definition that has been given. Until recently, any approach with a glideslope was precision. The LDA with a glideslope contrary to popular belief, was a precision approach. It is now considered "precision-like" due to an expansion in the definition.
Paul, here's the reply from earlier:
The AIM while guidance is not specifically regulatory and I wouldn't base a regulatory decision off it. Nothing has changed in the FAR's in regard to LPV/LDA, the wording in the AIM has changed but that isn't specifically legally binding (though it does further support the concept that only a ILS/MLS/PAR are precision approaches).
Precision approach procedure means a standard instrument approach procedure in which an electronic glide slope is provided, such as ILS and PAR.
7. TERPS criteria are provided for the following types of instrument approach procedures:
(a) Precision Approach (PA). An instrument approach based on a navigation system that provides course and glidepath deviation information meeting the precision standards of ICAO Annex 10. For example, PAR, ILS, and GLS are precision approaches.
(b) Approach with Vertical Guidance (APV). An instrument approach based on a navigation system that is not required to meet the precision approach standards of ICAO Annex 10 but provides course and glidepath deviation information. For example, Baro-VNAV, LDA with glidepath, LNAV/VNAV and LPV are APV approaches.
(c) Nonprecision Approach (NPA). An instrument approach based on a navigation system which provides course deviation information, but no glidepath deviation information. For example, VOR, NDB and LNAV. As noted in subparagraph i, Vertical Descent Angle (VDA) on Nonprecision Approaches, some approach procedures may provide a Vertical Descent Angle as an aid in flying a stabilized approach, without requiring its use in order to fly the procedure. This does not make the approach an APV procedure, since it must still be flown to an MDA and has not been evaluated with a glidepath.
Again, the information has already been covered and provided in enough scope and detail that as stated before, no further response should be necessary. All the "I think it should mean" or "it ought to say" in the world doesn't change what's provided, and what's provided is clear enough.
Your right I should have been more clear in my resposne. An LDA with a G/S has never been considered a precision approach by the FAA.
Not so. Given the clarification which has been added to the AIM, we see specific categorization of the LDA with glideslope as precision like, but not precision. However, the purpose of Part 1 of the regulation is to define the regulation, and the definition in Part 1 for a very long time now has simply been that a precision approach is an approach procedure with an electronic glideslope.
As you can see, lacking the recent clarification by the AIM, and operating by the standard of 14 CFR Part 1 as the proper and official definition, an LDA with glideslope certainly was defined as a precision approach. It is no longer so defined, given alignment with ICAO Annex 10, and this is a change.
I also find that GPS is a Global Navigation Satellite System Landing System. Redundency aside, what defines this? It appears to have something to do with WAAS and LAAS. Do any exist in the US/in the World?
Hot off the FAA press (bearing in mind that the FAA press can be stone cold):I have not seen such an approach anywhere, but there appears to be some sort of experimental system in place in Memphis. Is this associated specifically with LAAS?
For Immediate Release
September 21, 2009
Contact: Tammy L. Jones
Phone: (202) 267-3883
FAA Approves 1st U.S. Ground Based Augmentation System
WASHINGTON, D.C. — The Federal Aviation Administration (FAA) announced the approval of Honeywell’s Smartpath Precision Landing System, clearing the way for increased safety and efficiency at airports by providing precise navigation service based on the global positioning system (GPS). The first U.S.-approved system is located in Memphis, TN and will become operational early next year.
“The approval of Honeywell’s system marks the successful completion of a partnership between the FAA and Airservices Australia to build and certify a ground based augmentation system (GBAS),” said FAA Administrator Randy Babbitt. “We expect GBAS to become an asset to airports around the world.” Airservices Australia is expected to approve their system soon at Sydney Airport, Australia.
GBAS augments the GPS to provide precision approach guidance to all qualifying runways at an airport. It monitors the GPS signals to detect errors and augment accuracy by transmitting correction messages to aircraft via local radio broadcast. GBAS will initially supplement the legacy Instrument Landing Systems currently used at airports.
The FAA’s NextGen Implementation Plan identifies GBAS as an enabler for descent and approach operations to increase capacity at crowded airports. The Honeywell system is approved for precision approach operations down to 200 feet above the surface. GBAS will be improved over the next few years to guide an aircraft down to the runway surface to support zero-visibility operations and provide precise positioning service to enable performance-based navigation, area navigation (RNAV) and required navigation performance (RNP) operations.
RNAV enables aircraft to fly on any desired flight path within the coverage of ground or spaced-based navigation aids, within the limits of the capability of the self-contained systems, or a combination of both capabilities. As such, RNAV aircraft have better access and flexibility for point-to-point operations. RNP is RNAV with the addition of an onboard performance monitoring and alerting capability.
I say that as one who remembers A quadrants and N quadrants.
I learned AN ranges and celestial nav before I learned VOR's; I know exactly what you mean. ...
