User997 said:No types needed for any King Air's except the 300 and 350 series.
Yeap, same type. Sorry for the confusion.minitour said:Which are the same type, correct?
User997 said:Yeap, same type. Sorry for the confusion.
BE200Driver said:not sure which model 90 you are asking about but in the 200 we see 800lbs/hour down low and 600-650 at the higher altitudes. It can get better but we never get out of the low 20's.
the E90 at max cruise power @10,000 will brun about 700/hour. Up in the low 20's 450-500/hour.
The 300 has a MTOW of 14,000 vs the 200's 12,500
cvsfly said:I agree. Our B200 (PT6-42 = 850 shp) operates 350 hrs Block/310 Flight (Hobbs) per year. Average 1.4 Block/leg, 1.2 Flight/leg and 98 gal/Block Hour at 6.7 lbs/gal = 656 lbs/hr. Mix of legs as short as 50 nm and up to 900 nm, average 276 nm/leg and altitudes 5000 to FL 270, probably averaging FL 220 - 230. We run at 750 ITT or 2050 ft-lbs and 270 (summer)-275 KTAS (winter) (based in the South) at altitude. Training notes I have put a C-90 (PT6A-21= 550 shp) at 500# 1st hr, 400# 2nd hr if above FL180 and a 200 (PT6-41= 850 shp) at 700# 1st hr, 600 # after if above FL220.
minitour said:No worries...
I've also heard they're similar to the Beech 1900...any authoritative sources out there care to chime in?
-mini
JimG said:whoa....
I've been choked up about the 40 gal/hour block fuel flows I've been burning in my 340, since trading up from a Bonanza.
I know you can't really compare the two like apples to apples, but out of curiosity....what kind of airspeeds are you getting out of the E90 and 200 while in the low 20's?
JimG said:getting 215-220 knots, all on 40 gal./hr block (approx).
dhc8fo said:Just curious...anything special about your 340 that gives you speeds like that? I have a '79 and can't get more than about 170 kts and at any level (and all on 40 GPH)! That is one hell of a difference. Please let me know!
minitour said:Jim:
True or Ground?
-mini
Doh! That's not gonna work.DAS at 10/250 said:Or you could fly the other step-child King Air with 715/side. We get 250 ktas on 250 gal/side at 210.
Falcon Capt said:Avoid the King Air 100 and A100 like the plague... Basically a King Air 200 body on a short wing with little engines (680 SHP)... can you say "DOG"!?!?!?!
