Diesel said:The reason for modding an airplane is usualy an owner operator that likes their airplane and has had it for a long time. We ran into timed out engines after owning the plane for 10 years. We went with the walter's because even though the downtime is longer the cost savings by having no hot sections or fuel nozzel inspections are well worth it. Also at the end of 3000hrs you take the engine off and for 68k you get a new one.
There is a reason why Garetts were not put on any other King Air than the B-100. they are heavy, noisey, and a pain to maintain. Any engine that has more gears than a grandfather clock is just prone to more problems. the Pt-6 or walter is a simple engine that is ment to take serious abuse. The walter takes the abuse to the next level because it's a 7000hr engine. The FAA limits them to 3000 hrs.
Most A or B models have a new avionics panel. Not for the look cool factor but for the factor that taking out the stock radios takes about 150lbs of weight out of the nose. That alone is worth the new radios. I wouldn't replace the radar though. Some of the older radars can give you an xray scan of a guy on the ramp. Ground safety was not really a keyword back then.
Interesting. In all the time I have flown both engines. I have had no lose failures in the Garrett and three in PT6's. The reason I was given for Beech not going to Garretts for everything is the KA community didn't like the fact that the B100 didn't fly like a "King Air". The engine is noisy, but is reliable and more fuel efficent than the PT6.
There are still many A's and B's out there with original radios or early 70's updates. And I would definately replace the radar. Repair costs are now getting almost as high as replacement with a new up to date unit. Replacement of the radios is not only to reduce the empty weight, but also to increase the capability of the aircraft.
And resalability is something to consider. Because someday a more capable aircraft may be desired. I have found that engine mods decrease the desirability of many aircraft.
