JetBlue emergency landing (merged)
  • Thread starter Thread starter English
  • Watchers Watchers 49
"I heard on TV that the crew did an autolanding, that's why it looked so good."
I don't think that they would do an autoland in this kind of situation
It looked like they touched down quite a bit past the blocks. If I understood autolandings correctly, that should plop you down right on the 1,000 foot marks, correct?
I know, this goes into the Monday morning QB category; Does anybody else think that maybe they should have put a stand under the nose jack point asap? Before off-loading pax?
Yeah I thought of that, but I didn't want to post it because I thought it would be in poor taste.
cjs said:
How likely is it that JBU292 would be on socal approach seeing as how this is an emergency? Also, haven't spotted any orbitting A320 on passur yet ..
It's very likely that they would be on SOCAL approach. They don't change to different freq's just because you have an emergency.
cjs said:
I'll be the first to admit that I don't know much about aviation, but doesn't this underscore how dangerous it is to not have fuel dumping facilities available? In order to avoid an overweight landing, the aircraft in distress must orbit for god knows how long with whatever problems they're having as opposed to just dumping the fuel and making an immediate landing.
If you have a bad enough problem you make the overweight landing. Having a gear stuck in the wrong position isn't a problem that makes the a/c unflyable. Having the pumps and plumbing to be able to dump fuel takes a lot of weight and expense that is better used on other things.
how big/deep of a gouge do you think the nose gear left in that runway? is it closed indefinitely now, do you think?
One of the guys that Fox interviewed said "these guys have the best training, they are airline pilots not general aviation pilots".... some people think all GA is some old guy flying around in a Cub, I wanted to strangle the dude.
Here's a great quote from AP:
Crippled Jet Lands Safely at L.A. Airport
Sep 21 9:24 PM US/Eastern
LOS ANGELES
A JetBlue airliner with its front landing gear stuck sideways safely landed Wednesday, balancing on its back wheels as it slowed on the runway at Los Angeles International Airport.
and also they made it seem like touching down with the mains first was unusual. According to them, 3 point landings are normal. Gotta love the knowledgeable media.
