JetBlue control problem over Vegas yesterday?
No, but the absence of a LAND ASAP ECAM tells you the manufacturer thinks it is OK to continue the flight at least long enough to not do an over weight landing.
Remember the BA 747 crew that caged one and then flew all the way from the west coast to London on 3 engines? They got second guessed quite a bit in the industry. I popped one of the 3 hyd systems at altitude on a transcon, and finished the flight without incident and without any FAA Monday morning quarterbacking just because I did not get the LAND ASAP.
It's a bus thing, but quite handy if you know the logic behind ECAM and are up on your systems knowledge. The bus is very easy to fly, but can get really complicated real quick if you are having a bad day.
They actually diverted prior to Manchester for concerns of low fuel to to the 12% increase in fuel consumption. Also with fire reported shooting from the engine prior to shut down who knows what other damage could have occurred.
Pretty easy to be a Monday QB.
With the loss of the Yellow and Green system, you get no reversers, no braking except approx 7 applications of the parking brake, no nose wheel steering, and only 1 spoiler per wing.
That would have been pretty brutal being overweight in LAS.
Did anyone see a picture of the JetBlue airplane after landing in Vegas? Was the RAT deployed? Does the PTU get to do it's full self-test when doing a single-engine taxi followed by the second engine start and immediate takeoff?
With no loss of electrical I doubt the RAT had to be deployed. I am not sure what JB uses for wait time. But we use 3 min after 2nd engine start before we can takeoff.
If I was only on blue hydraulics, I'd want 2 sources to power that baby!
It's a good thought but it might not actually work that way. They might not work in tandem at all. The RAT might only come on line if the blue pump has failed, which means you're deploying it needlessly, or it may override the blue pump, meaning you're trading a known good component (the electric pump) for a unit that probably hasn't been in operation since the plane was delivered. I'd probably stick with the checklist on this one.
One system overheated, the overheat will fault the ptu.
Can you land the Airbus with no hyd at all, or are you screwed?
Did it in the sim as an exercise, which was interesting. I'm not sure I could repeat it in real world conditions. There's a sort of very low level reversion mode that really is only supposed to be used to keep the plane upright long enough to get one or more of the other systems back on line. It's not intended to land with. Think Sioux City.
But in order to lose all three, you either took a SAM hit that tore up three different isolated systems and lost all your fluid -or- both engine pumps, two electric pumps and the RAT would have all failed. Either you're incredibly unlucky or hydraulic failure isn't your only problem. Bad day all around.
Yeah, the self-test only takes a few seconds when you start the second engine. JB has a two minute warmup if the plane has been on the ground for less than two hours, otherwise it's five minutes, so that isn't a factor.
I believe people may be confusing the loss of all hydraulics on the Airbus with the loss of all flight control computers...
Two distinctly different scenarios.
I dont give a crap what airline, what airplane, background of crew, or how fat the FA's are. When you have a some pilots who are in a bad place and they safely land an aircraft without hurting anyone..............Fu#king great job guys and gals.
Totally agree, I would like to buy those guys a beer or 2
With all of that, they check the Landing distance table for 35C and 2400ft elevation @167k lbs (Guesses) and it says they're going long. I think the decision is made, hold and burn. Easier to hold with 2 engines and the Blue, than worrying about winding up in the Luxor's lobby.
There is a 35C in Vegas ? I'm not a BUS guy but was this a 0 flap situation given the problems they had ..
Was Nellis a consideration?
S
Flaps zero, or jammed where they are, slats functional...
Victorville is close by. 17/35 is 15,050 ft. http://en.wikipedia.org/wiki/Southern_California_Logistics_Airport
If that's not enough runway, there's no Luxor to be concerned about in Victorville; just tumbleweeds.
Four hours is an excessive amount of time to remain in the air with a hydraulic malfunction.
Airbus wants you to wait 40 seconds after closing the cargo door to start the second engine, perhaps to allow the yellow system to fully depressurize. If you single engine taxi with the electric yellow on and then switch it off and immediately start it, does the self-test see a pressure differential long enough to completely test the PTU?
One of the most common reasons for the yellow system to overheat is a stuck cargo door switch. I find it incredible that the green system failed and very shortly there after the yellow overheated.
The more reasonable scenario would be an overheated yellow system faulting and causing the PTU to fault with it, leaving a green system by itself (not a huge deal). So how did they end up without a green system?? I guess we'll find out someday.
Def a possibility. I'm just trying to think inside their heads. With no steering, they're probably thinking they have to deplane on the runway if the FBO doesnt have a proper bar and stairs. Dunno what kind of services they have. We had one with a similar problem out of Bogota. Not sure what they did.
The 40 second delay is because operating the yellow pump with the cargo door switch inhibits the PTU, to keep the PTU from pressurizing the green system when all you want to do is operate the door. I don't think it has anything to do with pressurization time. There's a lot of input into the PTU activation logic, and pressure differential is just one of them.
I don't know enough about the LAS scenario to speculate on why two systems would have dumped one after the other, but it does seem suspiciously like they weren't completely independent faults, doesn't it? It's certainly worth investigating. I just hope they don't try to fault the crew (again).
Great idea. Screw waiting for the facts, lets just go on what the media and ATC tapes say and make up the rest. Hell we can fix this deficit problem by getting rid of the NTSB and just using you guys!
Well, with all the integration between systems, I can see how a procedure could be implemented that seems straightforward enough, but in fact causes an unforseen conflict that doesn't make itself apparent until an emergency arises.
The crew does the best they can with the info they have, but training limits its scenarios to the failures that happen they way they should, instead of failures that fail in ways you don't expect.
