Fins Up
Fly Fast, Live Slow
- Feb 7, 2005
More like an AAbacus.
That's funny.
I hope we NEVER go to an ACARS based system for that. Takes me less than 30 seconds to re-do numbers for different runways, intersections..ect. We can manipulate everything...thrust, flaps, bleeds, APU and a few others...and no paper needed.
ACARS gets MEL'd sometimes...that'd suck with the other system. Not sure how you get around that one for those guys.
To put things in perspective, a certain non-sched I used to work for as recently as 2007 used this procedure on the MD11:
Five minutes prior to push the Ops Rep would give three or four different fuel slips to the FO along with a pax count by zone and cargo loads by hold. The FO would then research the empty weight and CG of the aircraft by way of the latest Config Sheet then enter all the information on an 12 x 20 inch load sheet -- being careful to utilize the correct load sheet for the configuration (three possible load sheets.) He would then enter the ZFW, Pax and Cargo Loads and, using a ruler, plot a ZFW CG on a graph. He would then add up the fuel load (converting litres or gallons to lbs using the latest fuel density reading) and calculate a TO weight and then plot a TWCG, again utlizing a ruler, on the chart. He would then pass everything to the captain for his signature and then tear one copy of the load sheet off to hand to the Ops Rep.
Non-sked vs major: miles apart in so many ways.
Yeah, World tends to complicates things.
