IXLR8
- Feb 14, 2006
JetBlue will surpass Delta as the top carrier at Boston Logan this spring. That's according to The Boston Globe, which writes Delta this week announced it "will stop direct flights to at least six cities from Boston and roll back daily service to two other destinations." With that, the Globe says Delta will end up "surrendering its spot as Logan International Airport's largest carrier based on the number of destinations served ... ." By early June, the Globe says JetBlue "will get the top-dog bragging rights with 31 (nonstop) destinations," which will compare to about 25 by Delta. As for Delta, the airline says it is dropping some Boston routes as soaring fuel costs start to turn some marginal routes into money-losers. During the past few months, the carrier has already dropped numerous other routes –- and even entire destinations –- as fuel costs have soared. In June, Delta will end nonstop service between Boston and Las Vegas, New Orleans, Savannah, Louisville, Greensboro (N.C.) and Charleston (S.C.).
"Most of it is going to be on your point-to-point flights, flights that aren't routed to our hub and that are served by 50-seat regional jets that are disproportionately impacted by the high cost of fuel," Delta spokeswoman Delta spokeswoman Susan Chana Elliott tells the Globe. She says more cuts are possible, though she tells the Globe Delta could eventually opt bring back some flights on a seasonal basis.
Despite Delta's pullback, the Globe says JetBlue "is betting on robust business in Boston." JetBlue spokesman Sebastian White says: "Despite all the talk of an economic downturn, our Logan flights continue to do quite well. Boston is an affluent and sophisticated market that likes to travel and does so often." (Related post below: JetBlue makes Orlando
