NTSB Identification: DCA05IA072
Scheduled 14 CFR Part 129: Foreign operation of Air Canada Jazz
Incident occurred Thursday, June 09, 2005 in colorado spring, CO
Aircraft: Bombardier, Inc. CL-600-2D15, registration: CGJAZ
Injuries: 66 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
An Air Canada Jazz Bombardier CL-600-2D15, tail number C-GJAZ, operating as flight number JZA8501 from Houston, Texas to Calgary, Alberta Canada, experienced a stick shaker event while at flight level 410 and in the vicinity of Colorodo Springs, Colorado. The airplane was at Mach 0.070 when the flight encountered a downdraft and the stick shaker activated. Maximum thrust was set and a lower altitude was requested. The airplane descended at approximately 1000 feet per minute with a 3 degree nose down attitude. An attempt to recover at flight level 400 was made but the stick shaker activated briefly and the descent was continued. Recovery was made at flight level 380 and the airplane returned to a planned speed of Mach 0.77. There were 62 passengers on board and no injuries were reported. Transportation Safety Board Canada has secured the flight data recorder and has provided an accreditted representative to the investigation.
