Instrument Checkride this Wed.. dont feel prepared..
  • Thread starter Thread starter QuasarZ
  • Watchers Watchers 14
Book mark stuff in the FAR AIM youre not too sure about and when he asks that question turn to that page asap....dont spend time looking it up use sticky notes.
QuasarZ said:
Do you happen to have an answer page for that? There are a few on there I dont know and cant find.
I personally don't have a Q/A sheet as I am not affiliated with that school. I just though that it was very comprehensive in terms of what knoweldge should be owned.
There are some questions that probably don't apply to your area/aircraft/equipment. You can tailor those into generic questions that apply to you airspace, aircraft, etc.
Everything else can be found in the FAA Instrument Flying Handbook and FAR/AIM. By researching the answers, they'll stick in your head. Any questions you're stumped on, make a list and post them on this thread. We'll all comtribute and help answer these questions.
Good luck.
I see your ride is on Wed...well, I'm pouring screwdrivers right now...so that must be an omen that you're going to do ok. At least that's what I'm going to tell the wife when she gets home from work and asks, "what the hell are you celibrating now, dammit?" (got to work on WED).
Pick a time that you think you should be done studying in the evening and quit beating yourself up...get a good nights rest and don't crack any more books in the morning.
QuasarZ said:
Tomorrow at 12:00
ooops...after I posted I saw the thread banner and said WED in big print. Duh! That happens when you get old.
Good luck tomorrow dude!
Couple questions... Any tips on doing a full approach partial panel? And any tips on doing a dme arc? I only have done a DME arc a few times.. so I am hoping that I do not have to do it.
Also, I have only done one auto-pilot couled approach and I asked my instructor if I would have to do one and she said "NO." Which I find hard to belive... I think that she needs to get a new PTS.. no auto pilot approach but some steep turns and stalls..?? I dunno..
but any tips on how to set up the autopilto approach?
Here's how I flew it:
I flew a DME arc approach with my Garmin 430 and Sandel showing me the line, so I had it easy, but if you don't have that, slowly fly the DME. If your distance starts to shrink, turn out 10 degrees and hold that for a moment. If it starts to increase, turn in 10 degrees and hold it for a moment. Don't chase it and over-correct....you've got a mile.
I was taught to think in terms of 10 degree increments. Turn 10 and hold it...turn 10 and hold it...turn 10 and hold it....
As far as the auto-pilot...I used mine. Why wouldn't you use everything at your disposal?
However, I flew the heading bug, rather than tried to couple it (mine at the time wasn't the easiest AP to work with anyway) when I was under a heavy workload and the DE was trying to distract me with questions, etc.
Here's what I remember from my instrument checkride from 3 years ago. The oral lasted a hour. The DE looked at my 8710 and logbook, 15 minutes. I gave him my flight plan that I did the previous night he filed it away. We talked about how long ATC would hold a flight plan before canceling it. We talked about the requirements for filing an alternate. He told me a story about flying through a squall line during his corporate days. We talked about AWOS. He briefed the flight portion of the checkride.
For the flight I filed to go to a Class C airport 20 miles north. I did 1 precision and 1 non-precision approach. Both involved radar vectors to the final approach course. Returned to our home airport. I performed a vor approach where he covered the AI. Once again via radar vectors. The flight portion did take some time because we being vectored around with the big boys(737's/757's). ATC was not happy handling a warrior.
jesus, this thread has me nervous as hell!!! i take my instrument and CFI-I written on thursday, end-of-course prog (4 hours!!!) on sunday, and if i pass, checkride mon or tues (hopefully). don't forget to add GGGGSCAR for the IFR-required list to go with ATOMATOFLAMES:
Gyroscopic heading indicator
Gyroscopic rate-of-turn indicator
Gyroscopic pitch and bank indicator
Generator or alternator
Slip/skid indicator
Clock w/ working seconds hand
Altimeter (sensitive -- meaning needs to be adjustable EX: kollsman widow)
Radios
that's in 91.205
good luck on wednesday!!! let us know how it goes!!! i'll keep y'all informed about my instrument adventures as well.
cforst513 said:
...don't forget to add GGGGSCAR for the IFR-required list to go with ATOMATOFLAMES:
Slip/skid indicator
Radios
GGGGSCAR is new on me.
I always heard GRABCARD
Generator
Rate of turn indicator
Attitude indicator
Ball
Clock
Altimeter (Sensitive)
Radios necessary (VOR, ADF, whatever)
Directional Gyro
Either or...good luck on your checkride(s) cfrost...I'm sure you will both be fine.
-mini
Page 15 of the PTS (emphasis added): The applicant is expected to utilize an autopilot and/or flight management system (FMS), if properly installed, during the instrument practical test to assist in the management of the aircraft. The examiner is expected to test the applicant's knowledge of the systems that are installed and operative during the oral and flight portions of the practical test. The applicant will be required to demonstrate the use of the autopilot and/or FMS during one of the nonprecision approaches.
Sorry I cannot give you any tips on the autopilot approaches, have not been lucky enough to have flow a plane with autopilot. In my case that is a luxury.
Good luck on your checkride, I am sure you will do fine. Just enjoy the flight and treat it as another lesson, both of you learning from each other!
