I've refueled fixed wing (A-10) from the boom and rotary wing (HH-60) from the drogue. I'd have to say that the drogue is more difficult, but whether that holds true for fixed wing drogue refueling I couldn't say. There's a lot of close-in receiver (trailing aircraft) movement involved with helicopter drogue refueling, which really got my attention the first time I did it. The stabilize, get stuck and hold what you got method of boom refueling is pretty tranquil compared with refueling in the helo, where you make a run at the basket from 5 or 10 feet back, hit it, and then reposition up and left (or right) to get away from the HC-130's horizontal stabilizer. As someone else noted, the basket isn't very far from the tip path of the rotor. It can also get pretty interesting on goggles or in turbulence. There are also enough light signals to piss off the pope.
Whoever mentioned IMC, that's a given any time you cross either ocean. There is a special course on seeking out IFR conditions at tanker school, you know. If it's CAVU except for a layer at FL210, guess where your ALTRV is, and no block for you.
You haven't really lived until you've spent a couple hours as #3 on the tanker's wing in that thick cumulus stuff over the North Atlantic. Doing it on the wing a KC-10 increases the enjoyment even more since something makes them surge back and forth a little, which plays crack the whip with your 1LTs. Any KC-10 guys out there that can explain that one?
Having said all that, the tanker guys really loved us in the A-10, spanning the globe at FL230 at a blistering 220 indicated. What flap setting is that in a KC-135 anyway?
