Mesabi Miner
- Jan 11, 2004
everything within 30 miles of the main bang.
I'll bet 75% of pilots don't know what the "main bang" is. Somebody took their ATC class!
MM
MM
The spot on the plan where the radar antenna is at.
Because its not a localizer approach.
The approach is an ILS approach no matter what. If the GS is OTS, then the controller will still clear you for the ILS approach, but its the pilots responsibility to fly it localizer only.
But if you deviate too low on the GS doesn't approach get an alarm? My point is if you use the dive and drive method to fly the LOC then you are going to be way below the GS. Right?
Jim
No, any alarms would be a "Low Altitude Alarm" which is generated based on obstacle clearance and rate of descent. The parameters in the facility should be set so that it will not alarm if the approach is flown as depicted. I suppose if you really pulled the power off rapidly at the FAF and came down like a stone to non-precision minimums you could probably could cause an alarm in the approach facility and they would call you to "Check Altitude". But that would be because of a rapid descent rate which causes the computer to look ahead and then go into alarm.
DC
The 7110.65 says "cleared ILS runway 36 approach, Glideslope unusable" in section 4-8-1 FYI.
