UndauntedFlyer said:Just to put things in perspective for large glass airplanes such as the 777: The F/D is on 100% of the time from take off to landing. The A/P is usually turned on any where from 12,000 feet to cruise level off. Most pilots have the A/P on by FL180. It remains on until about 10,000 feet or anytime thereafter with most pilots shutting it off by about 3000 feet if the field is VFR. For IFR the A/P will usually be on until the runway is in sight. Of course for an autoland it will be on until the airplane is at taxi speed. Autolands are only used when the weather is at CAT I minimums or below, or for A/P currency. No one ever flies with total raw data. Auto-throttles are used nearly 100% of the time except about 15% of pilots turn off the A/T's for approach and landing. The auto-brakes are used for 100% of all takeoffs and landings.
Some people ask if automation takes the fun out? My answer is that it does not. The automation is all gee-wiz stuff and exciting to operate.
If you like the Honda Gold Wing you'll love advanced airplanes. If you like Harleys then you'll go for A Squared's DC-6. It's all a matter of choice from one extreme to the other and anywhere in between.
So you decide, which do you like, the Gold Wing or the Harley?
