I don't understand this type of landing.
nosehair said:
No, you are not wrong. We are talking a typical tricycle trainer. Nose high near stall landing attitude. If the tricycle had a tailwheel, the tailwheel would be touching down with the mains. This is the correct way to land a light airplane, and keep the nose up as long as possible.
Well that's kinda what I figured, and I'm glad to see I'm not the only person to think this.
nosehair said:
Avbug must be talking about King Airs or something.
The world may never know...
Skyline said:
A big jet is flown with power on until just before touchdown. It makes for a stable and safer approach. Big planes can't recover very easily from large sink rates or other abnormalities like fast approach speeds or slow speeds.
When you practice a soft field landing it is similar to methods used to land a big jet. Power on throughout the approach untill just before touch down. Most small plane pilots are taught to fly the pattern with lower power settings and some are at idle. That makes for a steeper approach. If you did that with a big plane you would make a big hole on the end of the runway because you wouldn't be able to recover from the high sink rate at the bottom. FedEx lost a 727 due to that very thing.
Adding power will raise the nose of the plane making for a flatter attitude on approach and the "nose high" look that you see big jets have on approach.
Such details were not evident to me, but no longer. Thanks for clearing it up.
mar said:
So, lots of lift required for approach speeds means high angle of attack on swept wing aircraft and the engines "should" be above idle in case of a go around.
I see what you're saying. So would it be correct to say that most jets/swept-wing aircraft fly much "flatter" approaches to land than does the typical 172???
I remember the last landing I did, about a week ago. I apparently lost too much altitude before reaching the runway, and ended up having to fly for quite a distance over the ground, almost level, with power on (obviously). When I was over the runway I cut the power. Even though I didn't intend to approach/land this way, it was without a doubt the shortest landing I ever made. I even got to take taxiway delta back to the ramp, never done it before. Is this basically how a swept-wing airplane lands all the time???
No, you are not wrong. We are talking a typical tricycle trainer. Nose high near stall landing attitude. If the tricycle had a tailwheel, the tailwheel would be touching down with the mains. This is the correct way to land a light airplane, and keep the nose up as long as possible. The nosewheel is a "Taxi-Gear" not a "Landing Gear".
Unanswered lumped all aircraft into one, or at least, all light aircraft into one.
Conventional gear aircraft are landed both two point and three point, with two point being just as good as three, and often preferable. When two point, they're not landed nose up, but nose flat, often with forward pressure on the stick.
King Air's are landed just about like anything else with a nosewheel.
Three point landings, generally speaking, for nosewheel airplanes are destructive and poor airmanship.
No. What you did is very unsafe, dragging it in with power. If your engine failed, you would end up in the grass. You must learn to recognize any adjustments your glidepath needs early enough that you can make adjustments so as to always be able to reach the runway at idle or no power.
Well I certainly didn't do it intentionally. Funny thing is, instructor claimed it was a good landing...:confused:
then change instructor. if that was a good landing for him then he is probably milkin ya for money/time. has he not taught you how to use a VASI/PAPI??
Never heard of it.
Just kidding! But I thought those were only used at night??? Either way, I don't recall ever seeing the projection units on approach, in all my 20 hours.
UnAnswerd said:
Never heard of it.
Oh for crying outloud, enough people. Nobody is this much of a tool. Just ignore him.
It may have been a good landing, but it was a poor approach. They are two different things. And VASI/PAPI units are on all the time, and are used day and night. If you haven't seen them during the day then you are either color blind or fixating.
And really, who needs those? Just aim at a point on the runway.
If the point goes up, you're going down.
If the point goes down, you're going up.
If the point doesn't move and gets bigger...you're headed right for it.
-mini
...aahh, I see. You are taking the term "3-point" to mean, as in a tail wheel 3-point landing with both mains and tailwheel touching down at the same time; and you are thinking we mean "3-point" in a tricycle to mean touching the mains and nosewheel at the same time....No,No,No, that is not the dialogue here. We all (I think) are talking about the "attitude" of the nose. The tricycle is landed with the nose up AS IF it were a tailwheel, hence, the term "3-point" attitude.
"Point" with respect to landing, assuming you aren't going for style points, refers to the number of points that touch down at the same time, or that are intended to touch down at the same time.
A nose high two point landing on the mains is NOT a three point landing. It is a two point landing. A three point landing in a nosewheel aircraft means you land on the nosewheel and the mains.
If you land three point with your nose in the air in a nosewheel airplane, you've just dragged the tail.
What part of the word "attitude" don't you understand?
I see unanswered is not the only one who lacks understanding here.
A three point attitude in a tricycle gear airplane is the same as the taxi attitude. A two point normal landing attitude with the nose high and the nosewheel not in contact with the landing surface, is not the same as a three point conventional gear attitude.
In Oklahoma I gave an aviation merit badge class to some boy scounts. As I've always done, I offered each one who completed the merit badge an airplane ride. I borrowed a Cessna 150, and met them at a local grass airstrip. One boy was too short to reach the rudder pedals, and was very exicted about flying. It was the troopmaster's son. I explained to him, as I did each one that I would do the takeoff, and once in flight, he could fly the airplane.
During the takeoff, rolll, he leaned forward, wrapped both arms around the yoke, and then sat back quickly. The nose came up, the tail went down, and we dug a little channel down the runway as sod was scraped up between the empennage and the rudder. I cut the power and we stopped. No damage, but a little rut in the soft runway. After an inspection and a quick talk about our proceedures, we went flying.
If we had been landing, that would have been a three point landing in a tricycle gear airplane.
Your terminology is incorrect.
Further the nosewheel airplane may be landed with the nosewheel off the ground, but seldom landed as if it "were a tailwheel."
Funny how insurance companies, rental facilities, and even the FAA distinguish between someone trained in conventional gear, and someone not. If merely having the tail down and the nose up on a typical tricycle gear landing were enough to be the same as a conventional gear landing, what purpose would there be in having any training in conventional gear...folks would be flying one or the other without difficulty.
In the real world, however, that's not the case.
I don't know why, but for some reason, that Alec Baldwin SNL Boy Scout skit came to mind when I read that line.
-mini
ya but he still should know how to use them if hes hangin on the prop each time he comes in
Or the instructor could simulate an engine failure...fun stuff there, boys. I doubt if he'd forget it. Of course, the insurance company probably wouldn't forget it either.......okay, bad idea.
Yep, you are right, Avbug, we are technically incorrect in calling it a "3-point atiitude". Your description of dragging the tail in the dirt is a very-well-done graphic of the consequences of a literal interpretation of the term "3-point attitude" when refering to a tricycle gear airplane. It is meant as an exaggeration of the necessary attitude, which is somewhere a little short of a true tail-wheel-touching attitude.
Using this phrase is an instructing technique to get students to stop landing in a too-flat-attitude...but,wait, you knew that didn't you?
I prefer dealing with a student honestly, and calling a spade a spade. If I mean a nose-high attitude, then I tell the student nose high attitude.
Particularly with a new student or any primary student, telling the student to land the airplane like a taildragger has no meaning, if the student is flying a tricycle gear airplane. The student has no experience with which to correlate such an example, except perhaps having seen one on the ramp...this does little good in the cockpit.
If the student has a particularly hard time getting it, I'll tie the tail down and lift the nose and let the student sit in the airplane for an hour before we fly, visualizing the landing, then opening his eyes and seeing the landing attitude.
I'll do the same thing in a conventional gear airplane. In order for the student to visualize and understand a wheel or two point landing, I'll raise the tail of the airplane and place it in a truck bed or on a stand, and have the student sit in the airplane while mentally "flying it." The student gets the sight picture so that it's more familiar to him or her when we land. The student may go back and do this several times, as needed.
I explain to a student wile taxiing in a tricycle gear airplane that this is a three point attitude. Look outside, memorize how close you feel to the ground while moving...this is very close to what you'll see on landing, but with the nose in the air, just like it was when you were at the ramp with the tail tied down (or raised for a conventional gear airplane).
If I'm taxiing with a student in a conventional gear airplane, then yes, I can tell the student that we are experiencing the same proximity to the ground, in a three point landing attitude, that the student will experience when he or she lands.
I do not try to help a student in a tricycle gear airplane understand a landing by using incorrect terminology and poor examples, and by confusing the student using aircraft configurations and feelings and sight pictures that he or she has never experienced.
...OK, that's what you do. You use the term "nose-high attitude". There are lots of instructors who use the term "3-point attitude", and that is what the original question of this thread was about. Of course, you are right about the terminology; it may be confusing, like "take-off power" - which way is that?
That is your point - the terminology is technically incorrect - but the meaning is the same as it has always been - a "nose high attitude".
...OK, here's what I do...I have the student get on the runway, and do some "high speed taxiing"...we get enough speed to lift the nosewheel up to a landing attitude, and get the feel of directional control with the rudder pressure only...not with nosewheel steering. The new student gets the look of the nose-high landing attitude, and the elevator/throttle coordination, and the feel of rudder pressure to control direction down the centerline...in the landing attitude and control feel.
I don't use the "3-point" term either, (with tricycles) but it's out there...you can't stop it, just acknowledge it, explain it if necessary, and move on.
Many moons ago I hired on with a company flying twin commanders. I'd never flown one. Prior to ground school, the chief pilot had to take a checkride. Several of us flew down to the airport where the FSDO was located. I rode in back. They did the ride, the others left, and I flew back with the chief pilot.
This was my first chance to fly the airplane. We were parked on the line at this airport, with the POI watching. The chief pilot said that the airplane was easy to taxi, it taxies just like a "taildragger." He said, "If you know how to fly a taildragger, then you already know how to taxi this airplane."
Brakes released, and we began to roll forward. I pushed a rudder all the way to the stops, to no avail. I tried tapping the brake and got a jerky response, but kept taxiing forward. And forward. And forward.
"Come on! It's just like a taildragger? I thought you said you know how to fly a taildragger?"
At this point I was thoroughly confused. I tried pushing forward on the control column, to see if it would release a steering lock. Nope, not like a taildragger. I tried pushing rudders both ways. Nope, not like a taildragger. I tried using differential braking, but the results certainly weren't satisfactory. Nope, not like a taildragger. I tried doing all of the above while carrying power and using differential power. Nope, not like a taildragger.
Now of course, the twin commander is easy to taxi, and all he had to say was "start to apply a little toe pressure, and you'll get steering. Apply a little harder and you get brake." But he didn't. He kept insisting that the twin commander taxiis like a conventional gear airplane, which it doesn't, in any way, shape, or form. Perhaps he was trying to suggest that because he uses a lot of braking in flying a conventional gear airplane that everyone else does...or that getting the airplane to move might be like unlocking some wheels from their detent by tapping a brake. I don't know what he meant...if he'd have just used plain english and called a spade a spade, it would have come across a whole lot clearer.
...and if all the instructors in all the training flights we have all done would have always used the clearest form of communication so that we would have always understood the precise meaning of the intended communication...
...then we wouldn't be having this conversation...:)
It appears to me that the conversation has been prolonged not because of "all the instructors...", but rather because of the poor communication skills and usage of improper techniques of a single instructor.
The silver lining in the cloud is you've encouraged Avbug to more clearly articulate not only how the misuse of "three point landing" is technically incorrect, but is conducive to negative learning and perhaps unsafe. I wholeheartedly endorse his approach to the subject.
I agree. Avbug's description of the landing position of an airplane (whether conventional or tricycle) relative to the ground is quite clear. I could picture the entire scenario well.
--Dim
...as do I. and the whole point of these discussions is to encourage articulation so that information is better understood and distributed. See, even Dimwit gets it.
