I don't understand this type of landing.
Bandit60 said:
If what you say is all true then how come a learjet has a high angle of attack when on approach? It doesnt have slats. Come to think of it, the Falcon and Sabre are the only corporate jets that do have slats. (I'm sure there are more that I cant think of at this time.) My point is that most coportate jets do not have slats and most of them land with a high angle of attack
Cause corporate jets usually have the smallest wings they can put on them. A Lear is like the F-104 of corp jets. Plus a lot depends on the design of the wing... I am pretty sure a Lear's wing doesn't have much curvature to it so therefore it relies on angle of attack mostly to create sufficient lift. Flaps help a bit but it's darn near impossible to make a curved surface out of a flat wing even with flaps.
Remember the whole discussion about Newtonian lift vs. Bernoulli's principle in private pilot ground school? Barn doors can fly just as well as a cambered wing, it just all depends on the angle of attack. :)
Anyway I was using generalizations to explain myself in the early post. Of course there are always exceptions.
UnAnswerd said:
And so sure of this, that you even provided an explanation as to why.
Because in a conventional gear (tail wheel) aircraft, you will sometiems do a wheel landing where you land on the mains first and then set the tail down. Most helpful in strong crosswinds and in conventional gear aircraft with limited forward visibility
Do you land on both mains first or just the upwind wheel, then the downwind then the tail. call it the 123 point landing. Or you could land upwind first, let the tail come down then plant the down wind wheel. Hmmm call it a 132 landing. All of this takes into account that the numo 3 represents the tail wheel, which logically means that would not work for a nose banger.
bah, FN was right; never get high on your own supply!
There's this chick in my criminal justice class that wins every argument with the comment, "I'm a straight A student!" but she don't know the commerce clause from her ass hole.
I'm not sure what I just read in this thread. I feel like I just had some of FN FAL's supply. I'm confused.
Only at flight info could a conversation go from 3 point landings to something about Caravan X-wind landings to drug references to sexual innuendo. The worst part is, the poor kid's question was never answered. Gotta love it.
first of all....avbug.....you still are my hero
second.....unanswered...you are a F**KING retard
please stop before you become a statistic
and i will guarantee he will make some fake quote of me saying something stupid of myself
again
UNANSWEred should win a DEE DEE DEE award
Flare
UnAnswered
Big airplanes are basically the same as a 150 except on a larger scale with greater weight and momentum.
A big jet is flown with power on until just before touchdown. It makes for a stable and safer approach. Big planes can't recover very easily from large sink rates or other abnormalities like fast approach speeds or slow speeds.
When you practice a soft field landing it is similar to methods used to land a big jet. Power on throughout the approach untill just before touch down. Most small plane pilots are taught to fly the pattern with lower power settings and some are at idle. That makes for a steeper approach. If you did that with a big plane you would make a big hole on the end of the runway because you wouldn't be able to recover from the high sink rate at the bottom. FedEx lost a 727 due to that very thing.
Adding power will raise the nose of the plane making for a flatter attitude on approach and the "nose high" look that you see big jets have on approach.
Skyline
UnAnswerd said:
I may be wrong, but it seems to me that if you took a conventional geared airplane, and a tricycle-geared airplane, and completely disregarded the configuration of the gear, both airplanes are landed basically the same way....in a nose-high attitude at a speed at or near stalling.
No, you are not wrong. We are talking a typical tricycle trainer. Nose high near stall landing attitude. If the tricycle had a tailwheel, the tailwheel would be touching down with the mains. This is the correct way to land a light airplane, and keep the nose up as long as possible. The nosewheel is a "Taxi-Gear" not a "Landing Gear".
Avbug must be talking about King Airs or something.
That's news to us. Where did you hear about that?
The original question
UnAnswerd said:
I know enough about the three point landing, but if anyone could describe this other, special, apparently magical way to land a large jet, I would greatly appreciate it.
I got a little lost there, for a second, but I think this is the original question, no?
The magical way to land a large jet...you're going to be so disappointed when I tell you the secret because like most secrets it's compensating for a weakness....
Actually two weaknesses:
1) The swept wing is very inefficient at low airspeeds and therefore you need much higher angles of attack (compared to straight wing aircraft) to generate sufficient lift.
2) As you know, some turbine engines take a while to "spool up" from idle to "go around" thrust. Therefore, in the interest of safety, it's become a matter of procedure to have the engines spooled up before 500 or 1000 feet. If you didn't, and needed to go around, the power wouldn't be there fast enough.
So, lots of lift required for approach speeds means high angle of attack on swept wing aircraft and the engines "should" be above idle in case of a go around.
Flare, brake, clear the runway, go to the hotel. Repeat tomorrow.
Yes, but I wasn't talking about wheel landings. My post specifically referenced three point landings. Whether or not that term can really be applied in any way to an aircraft having a tricycle-gear setup, I don't know. But either way, it's pretty clear that Avbug will take into account every possible exception, every minute variation, and every irrelevant detail for the sake of arguing.
