As part of her punishment, she should...she needs the discipline.macfly said:In the end she will thank you.
UnAnswerd said:I may be wrong, but it seems to me that if you took a conventional geared airplane, and a tricycle-geared airplane, and completely disregarded the configuration of the gear, both airplanes are landed basically the same way....in a nose-high attitude at a speed at or near stalling.
That's news to us. Where did you hear about that?Skyline said:Most small plane pilots are taught to fly the pattern with lower power settings and some are at idle. That makes for a steeper approach. If you did that with a big plane you would make a big hole on the end of the runway because you wouldn't be able to recover from the high sink rate at the bottom. FedEx lost a 727 due to that very thing.
UnAnswerd said:I know enough about the three point landing, but if anyone could describe this other, special, apparently magical way to land a large jet, I would greatly appreciate it.
HS125 said:Because in a conventional gear (tail wheel) aircraft, you will sometiems do a wheel landing where you land on the mains first and then set the tail down. Most helpful in strong crosswinds and in conventional gear aircraft with limited forward visibility
