I agree with DCAinstructor. Sometimes I use 1600 RPMS instead of 1700.
Hi...
Just how is it done??? How do you properly land a C-172???
This week I went for my lesson. It was my first time in a C-172 SuperHawk....Big difference. This thing just wanted to haul A$$!
It begs to get off the ground! Anyways, I had trouble getting it back to the ground... I was told or have heard several times to land a C-172 that you have to stall it...Is this true? I have found this difficult in all the other Cessnas I've flown...which is why I do not like them....They all seem to float down the runway....I normally use the Piper warrior....my favourite...But it was in the hangar for 100Hr maintenence...
So how is it done? I keep bouncing my landings and this is extremely embarrasing and dangerous...I hold 65-70 Kts all the way to the runway,
but I bounce everytime!
My instructor likes the speed control but seems to think that I'm concentrating on a single spot to land on the runway rather than looking at the opposing end....I look further away but bounce anyways...Sigh...
Once I landed a c-172 fine without a bounce, and with that aircraft I have not been able to do it again.....Any advice helpful. Thanks.
tell those F'n DCA instructors to stop going to MESA!!!!!!!!!!!!!!!!
FLYHY said:Maintain this profile until you get closer and closer to the runway keeping the extended centerline through your legs and right on the VASI 'red over white, you're alright'.
Relax as you get closer and don't focus too much on any particular point on the runway.
First off, what model of 'Superhawk' are you talking about? The SP I assume?
On thing to mention regarding a 180 after departure with a failed engine. Always turn into the wind if a crosswind exists. This will allow you to remain more aligned with the departure runway should you need to turn back. A tailwind behind you will put you further away and require more manuevering. Since many airports have multiple runways which intersect, sometimes a 180 back to the same runway isn't always necessary. In terms of banking, I recall a study done which showed that an approximate 45 degree bank was safe and provided a better return on altitude during the turn than did a shallower bank. The shallower bank took longer to get turned around and left you further from the runway.
If you are looking to grease it on then here is the trick. Yes cross the fence at ref but at the same time keep rolling the trim nose up intil almost or full up; (on short final) that way you will not use so much back pressure and inevitably smack the mains down. Then just practice. Works every time. BUT; be ready on the trim if you have to go around; just shove the nose forward and start rolling the trim forward if that time comes! Let me know how it works.
As one of my mentors once told me, "Just fly the plane.". Every new plane takes some getting used to. Fly the speed you are supposed to in the configuration you are supposed to and just practice. Then again this advice may be unnecessary because you have probably moved on with your life by now.
Hey, where'd you get that avitar???:beer:
What happened? You go to the interview and all the DCA weeines get hired and you got the door? This was a thread about landing a dang airplane. Atleast they worked for the hours in their logbook instead of buying them at gulfstream. 'nough said.
