How to Properly Land a C-172.....
I agree with DCAinstructor. Sometimes I use 1600 RPMS instead of 1700.
There's not too much difference between 1600 and 1700 RPM. Obviously, you will see a difference by adjusting between the two power settings, but from day to day, the power setting will vary slightly based upon atmospheric conditions. One day 1600 will be enough, on another, 1700 RPM. Also, between planes of the same model, you will notice variance between what power settings will hold what speed with various ptich angles.
its not this complicated. First you should use what RPMs work and never have to look at the RPMs. Aprroachspeed doesn't matter at all, you should hold the 172 off until it makes the decision it doesn't want to fly anymore (unfortunately very few people get this b/c they over control a 172), which is completely different than "driving on" a piper. Last and most important, tell those F'n DCA instructors to stop going to MESA!!!!!!!!!!!!!!!!
Don't sweat it. You only have 11.5 hours, and it will come. Practice slow flight and stalls so that you have more confidence in your approach speeds. After that, it's just practice....
Hi...
Just how is it done??? How do you properly land a C-172???
This week I went for my lesson. It was my first time in a C-172 SuperHawk....Big difference. This thing just wanted to haul A$$!
It begs to get off the ground! Anyways, I had trouble getting it back to the ground... I was told or have heard several times to land a C-172 that you have to stall it...Is this true? I have found this difficult in all the other Cessnas I've flown...which is why I do not like them....They all seem to float down the runway....I normally use the Piper warrior....my favourite...But it was in the hangar for 100Hr maintenence...
So how is it done? I keep bouncing my landings and this is extremely embarrasing and dangerous...I hold 65-70 Kts all the way to the runway,
but I bounce everytime!
My instructor likes the speed control but seems to think that I'm concentrating on a single spot to land on the runway rather than looking at the opposing end....I look further away but bounce anyways...Sigh...
Once I landed a c-172 fine without a bounce, and with that aircraft I have not been able to do it again.....Any advice helpful. Thanks.
What happened? You go to the interview and all the DCA weeines get hired and you got the door? This was a thread about landing a damn airplane. Atleast they worked for the hours in their logbook instead of buying them at gulfstream. 'nough said.
I forgot to finish ~ sorry... I noticed you were flying a C172M which flies about 5 kts slower than the newer models. 65-70 kts is a bit high and 172s don't like being fast on final. Try 60-65 kts and that should help out.
I agree with an earlier comment that you may be landing nosewheel first "wheelbarrowing", which could be caused by you focusing on your aiming point throughout the flare rather than focusing at the end.
Try flying a long final 3-4 miles in the morning with the VASI or PAPI on. Set up for your final approach with 30 degrees flaps and the power setting to maintain 65 kts. Get it all trimmed out - if you let go and the plane doesn't do anything, that is perfect. Maintain this profile until you get closer and closer to the runway keeping the extended centerline through your legs and right on the VASI 'red over white, you're alright'. Relax as you get closer and don't focus too much on any particular point on the runway. As the bottom VASI turns red, slowly and smoothly reduce the throttle, shift your focus to the very very far end of the runway and continue to 'fly' the plane to the far end. This means that as you begin your flare, you have to pitch up just as slow as when you rotate, perhaps even slower, and just use your diminishing lift to smoothly land on your main tires first. GOOD LUCK!
A good 1500-1600 RPM approach in a C172 at 60-65 knots will yield about a 5 degree glideslope, which will show all white on a VASI/PAPI system anyway. Sure, a 3 degree glideslope can be flown, but it'll be at an unnecessarily high power setting. The nice thing about the 5 degree glideslope is that your point of touchdown will be nicely set at around the 90 knot level pitch attitude. It's a good attitude in that students already know where it is.
See, I disagree with that. I get my students to look for the "zone of no-movement," which is the point on the runway that isn't moving up or down in the windscreen as you approach the runway. If you were to maintain the same pitch and power settings all the way down, that's where you'd hit the ground. A good place for the student to reduce power is right when that point starts to slide backward towards your nose. Looking for a PAPI or VASI at that point is only going to get them to look to the side of the runway, not at the runway.
Also, what are they going to look for when they go to an airport without such a system?
Just my two cents.
If you are looking to grease it on then here is the trick. Yes cross the fence at ref but at the same time keep rolling the trim nose up intil almost or full up; (on short final) that way you will not use so much back pressure and inevitably smack the mains down. Then just practice. Works every time. BUT; be ready on the trim if you have to go around; just shove the nose forward and start rolling the trim forward if that time comes! Let me know how it works.
All these guys are way off in what they are telling you.
Be configured by 1000', be stabilized by 500' -- hold about 45-55% N1 depending on the weight -- and when the airplane says "20" reduce the thrust to idle and........wait, what forum is this? ;)
Super Skyhawk
CaptX That would be the porcedures for the Super Skyhawk that is turbin powered wouldn't it?
On thing to mention regarding a 180 after departure with a failed engine. Always turn into the wind if a crosswind exists. This will allow you to remain more aligned with the departure runway should you need to turn back. A tailwind behind you will put you further away and require more manuevering. Since many airports have multiple runways which intersect, sometimes a 180 back to the same runway isn't always necessary. In terms of banking, I recall a study done which showed that an approximate 45 degree bank was safe and provided a better return on altitude during the turn than did a shallower bank. The shallower bank took longer to get turned around and left you further from the runway.
Amen! You must have flown gliders!
-Goose
I wouldn't tell a student to do that in a million years.
-Goose
As one of my mentors once told me, "Just fly the plane.". Every new plane takes some getting used to. Fly the speed you are supposed to in the configuration you are supposed to and just practice. Then again this advice may be unnecessary because you have probably moved on with your life by now.
I couldnt agree more. I cant believe how techincal this thread has gotten. Numbers are nice but we all know what pitch and power does for us. Just find the combo of pitch and power that works for the situation and see what happens. If its not the right combo, go around and adjust. You already know how to land, just make it happen.
I've only done one (my first) flight (one assisted landing) but its interesting to see so many different ways people are landing these C172's. We were in a 172K.
I was just running two things through my head... pitch for attitude, throttle for altitude. K.I.S.S. - Keep It Simple Stupid :D
Bear one thing in mind: approach speed is relative to weight, you don't have to be flying a 747 to apply this. If you're lighter, fly a little slower.
Then again, I don't see why every one thinks of "soft landings" when you talk about "good landings." If you want a "good landing," put it down where you want it, aligned with the runway, in control, on the mains, and go easy on the brakes.
People get so fixated on making it soft that they often round out too high, side load, flat spot, blow tires, float halfway down the runway followed by excessive braking, hit the nose gear first, etc. Any 10 hour pilot can grease it on from time to time, but there's a lot more to saving wear and tear on your plane.
What happened? You go to the interview and all the DCA weeines get hired and you got the door? This was a thread about landing a dang airplane. Atleast they worked for the hours in their logbook instead of buying them at gulfstream. 'nough said.
Three things. I'm just trying to help the DCA boys and girls make a wise decision, mesa is hell, its worth holding out for anyone else. Second, I had no intention of hijacking the point of this thread, again just a brief sidenote trying to help people at DCA (although I kinda happy certain particular people went to mesa, some people deserve the torture). And third, I unfortunately in some ways and fortunately in other ways did the whole thing at DCA, just think about it, you'll figure out who I am, or maybe not I have been gone for quite a while now.
is N89989 still there, that plane rules!!!!!!!!!!!!!!
I teach 65 KIAS on approach, easing power out as approaching the threshold, power idle over threshold, level off at idle over the runway and ease back on the stick and the usual "don't let it land, don't let it land!" until touchdown. That'll usually get you to touchdown with the stallhorn. As aforementioned, 65-70 all the way to the runway will give you a non-trivial amount of float under most conditions. If you start easing back on the power before the threshold (from 65) and have it all the way out over the threshold, you should be crossing the runway at about 60 which, in my experience, works out quite nicely.
