How to Properly Land a C-172.....
VW Pilot
MMM...PIGEON CASSEROLE
Hi...
Just how is it done??? How do you properly land a C-172???
This week I went for my lesson. It was my first time in a C-172 SuperHawk....Big difference. This thing just wanted to haul A$$!
It begs to get off the ground! Anyways, I had trouble getting it back to the ground... I was told or have heard several times to land a C-172 that you have to stall it...Is this true? I have found this difficult in all the other Cessnas I've flown...which is why I do not like them....They all seem to float down the runway....I normally use the Piper warrior....my favourite...But it was in the hangar for 100Hr maintenence...
So how is it done? I keep bouncing my landings and this is extremely embarrasing and dangerous...I hold 65-70 Kts all the way to the runway,
but I bounce everytime!
My instructor likes the speed control but seems to think that I'm concentrating on a single spot to land on the runway rather than looking at the opposing end....I look further away but bounce anyways...Sigh...
Once I landed a c-172 fine without a bounce, and with that aircraft I have not been able to do it again.....Any advice helpful. Thanks.
VW Pilot said:
Hi...
Its been over 16 years since I have flown a 172, but I am sure it hasnt changed too much over the years. I was a CFI for 1745.1 hours. I always taught my students to fly above the runway at about 12 inches above the ground. With the throttle at idle, use the nose wheel as the pivot point...keep the nose at 12 inches above the ground...holding the nose up with the yoke..... and let the mains fall towards the ground. Once the mains are on the ground, keep the back pressure on the yoke, then slowly lower the nose.
It may not be the "proper way", but it worked for all of my students to get the feel of what is going on.
Good luck.
Your approach speed is too high, I teach cross the threshold at 60 KTs flaps 20 and 55 KTS flAPs full. Reduce the power, being mindful the nose will want to drop when you reduce power. Flatten the apporach, look at the far end of the runway, and watch the airplane sink, gentely apply back pressure, land in a nose high attitude. Never lower the nose. Just keep practicing, anyone can learn to land an airplane. But looking at the far end of the runway and sensing your sink rate is the key to pulling off decent landings.
Of course, without being there, it's hard to tell which of the many possible errors you are making, but let's try this one:
To me, that 65-70, while maybe a bit higher than necessary, is too low to account for a land and takeoff type bounce. The bounce may indicate that you are landing on the nosewheel, which means you're not keeping the nose off the ground at touchdown.
I see from you profile that you've flown PA-28 aircraft. One of the biggest differences between it and a 172 is the height of the nose during touchdown.
In general, the view out the window in a PA-28 at the point of touchdown allows see the runway in front of you while still keeping the nosewheel off the ground. The view out the window in a CE-172 does not - for most pilots, the nose of the airplane will block the runway. Unless you are really tall or your seat is cranked way up, if you can see the runway during the flare, the best you will do will be to land flat, but you are more likely to touch nose first and bounce.
The difference in the height of the nose off the ground during touchdown is one of the biggest differences I see among light singles. My tip is to notice the nose position when the mains first leave the ground on takeoff - that's the position the nose should be in when the mains touch down on landing.
See if your instructor will let you slow fly it the length of the runway a few times(5 to 20 feet agl or so). Teaches control and a light touch. Used to work well with my students on working out many landing problems..X-wind, hard landings etc etc.
Of course be mindful of any obstructions at the ends.
There are some great points here that everyone can use. Each instructor has a technique they use to teach, and althought they may be different, they all work. That is why if it not working with one instructor try another who may have a different approach to the same problem.
If watching 172's land at BFI is any indication, I would landing on all three wheels at the same time is the proper way to land a 172. Yikes!
Good luck-
I fly an older PA-28, with the airspeed indicator calibrated in MPH. So, I'm used to seeing like 85 on final, and maybe 70-75 over the numbers.
If the day comes where I ever fly a Cessna, it's gonna feel strange to look down and see 60, even if that is KTS and not MPH. You don't dare get a Cherokee down to 60 unless you want to stall...
Ditto about the 65-70 on final. That is too fast, I like to see 60. It dosen't sound like much, but it makes a huge differance.
Try this excercise next time you and your instructor go flying.
Fly your normal aproach all the way to the flare,
Then just when you think you are about 1 foot from the ground add some power and fly down the runway at that altidue of 1 foot AGL,
If you do touch down it will be very smooth, and you will lift off again with a little bit more power,
Don't forget to maintain directional controll, and start your go around with enough runway remaining.
On the next pass do the same thing without adding the power and you will make a very nice smooth landing.
I started demonstrating this to my students to show them what the flare picture should look like, and I have found it helpfull for fine tuneing the flare.
Something that worked for my students with the 172 while trying to nail soft field landings, was to set 1700RPM and leave it alone. Think slow flight above the runway. At 1700rpm, it WILL not want to fly and you will land it like butter.
Just slowly raise the nose as the speed decreases. Try it, this worked for lots of my kids. The 172 does not land like the 152. It wants to stay airborne, just remember you can never force any airplane onto the ground, it will land when it's ready to land. PERIOD.
We used 85kts downwind, abeam TD point, Carb heat, power to 1700 flaps 10.
On base, flaps 20 and the plane will slow to 75. Then flaps 30 on final and it will slow almost magically to 65. If it was trimmed on downwind and you trim when the power is first reduced to 1700, you "should" never have to touch the trim wheel again. Cessna actually designed this in the airplane.
See more here on http://www.whittsflying.com/
This guy's site is AMAZING! I am surprised I dont see more of his stuff here.
But, BOOKMARK it, you'll need it someday.
DCAinstructor is right. Althoughn I use 1500, if you do it correctly you should never have to touch the throttle untill touchdown. Just remember that the 172 has a very low stall number with full flaps and it will want to fly even at 55Knots touchdown speed. If you land at 65-70 you will bounce, if you have a crosswind and you bounce it could get ugly! Now, you can fly the approach at a higher speed but you should cut the throttle much earlier before reaching the threshold to bleed the speed. The 172 is a much more challenging plane to land but it makes good student pilots because the challenge.
Do I hear IP's are teaching to land power on? I have never heard of such a thing and never made a power on landing until I started flying the P-3. Yes during the early stages of teaching to land with power on as per above, but I would never solo a student who could not make a good landing when cutting the power at the threashold.
All good comments...Thanx to all. By the way. the warrior is out of maintenence, so it's back to my favourite low wing trainer.
I had the same problem. Initial training in Pipers, went to Cessnas and didnt like them. They love to float. Pipers drop when you cut the power. Cessna's float. DCA is right, force a Cessna to the ground and you wont have a good landing.
I agree, I won't solo a student unless I can pull their motor in the pattern (base or DW) and have them bring the aircraft to a safe landing somewhere on the runway. I teach both, power on and power off. After all if they can't land with power on, they are in trouble when the winds get nasty.
Maintain about 70 knots on final and crossing the threshold you should be about 65 knots. Keep the aiming point in your window and just point the plane towards this mark. Your focus should be just over the nose aiming for your touchdown point. When you get about 10-15 feet above the runway begin to slowly pitch the nose up. What you're essentially trying to do is prevent the plane from landing by holding it off. As you begin to pitch up, slowly move your line of sight focus from the touchdown point to the end of the runway and horizon. At this point you should be looking far ahead and feeling the plane sink. You'll feel the descent and see it in your peripheral vision. Continue to try to hold the plane off the ground as you flare.
Getting the landing right just takes practice. It's one of those things that one day it will suddenly click - and you'll begin to understand what it is you're supposed to be doing.
Before I would solo a student....I would have the students close their eyes as I fly the plane. I would bring down next to the runway over the grass ( this at an uncontrolled airport). Then I would tell them to look at where they are, take the controls back, and maneuver the plane to land.
This gives both of us confidence in the students understanding and ability.
huh??? This demonstrates what? You want to up their confidence, Can their motor at 700 feet when climbing straight out. IF they remember to turn around and can make the runway safely, buy them a steak dinner. I would actually do this in the simulator with the weather at 1/2mile and 100ftovc. The sharp ones were able to intercept the backcourse and actually make the runway. The rest of the sheep just crashed straight ahead into the abyss.;)
Hi...
One of my students was having issues with this. Let me see if I can help.
Before you even go and try to land the airplane again, go and review a couple common pitch attitudes.
First, review what Vy looks like. If you have your seat position set appropriately, Vy in the C172 should look like the horizon is passing right at the top of the glareshield. Make sure that your seat is set at such a height that your eyes are roughly even with the top of the door. You should only be able to see the first set of rivets on the cowling.
Second, go out and review what 90 knots level looks like. In a C172 (at least the newer models), this should be roughly 3 average sized fingerwidths between the glareshield and the horizon. Again, that's assuming the seating position I just described.
When you're actually coming down final, you should ideally be on a 5 degree glideslope at full flaps and 60-65 knots. I like closer to 65 knots. As you're looking down at the runway, you're obviously going to see the runway getting larger in your windscreen. Now, on that runway you're going to see a point (maybe a centerline or other marking), that is neither moving up or down in the windscreen as the runway is getting larger. That's called the "point of no-movement," and is basically where the airplane would hit the ground if you were to continue to fly it at that pitch and power setting. Keep an eye on that point as you're coming down final.
As you come closer to the runway, that point of no-movement is going to actually start to slide backwards towards your nose. When you detect that rearward slide, start a 3-second power reduction from 1500 RPM to idle. I don't mean a fast count. I mean a nice, steady "one one thousand, two one thousand, three one thousand" count. When you reach "three one thousand," your power should be at idle.
Directly after getting the power to idle, start your roundout by doing another 3-count. This time, you're going to smoothly add backpressure and raise your nose from that descent/approach attitude to 90 knots level. You should reach 90 knots level pitch as you hit "three one thousand."
By this point, you'll see the runway starting to rise up below you out of your peripheral vision. From that 90 knot level pitch, smoothly raise the nose to the Vy pitch attitude at the rate at which you see the runway coming up from below. You should reach Vy just as the wheels touch down, and at a full stall landing with no bounce and minimal float.
Anyway, it's 3am and I just worked an 11-hour duty day, so I hope I'm not leaving anything out. Feel free to add anything to this. Keep in mind that this technique does not fit everyone, so make any adjustments necessary.
Well, being that I taught for over 1700 hrs (more than your total time), I can assure you that if my student can recover from a bad approach and put it down nicely, we are both satisfied.
As far as doing a 180 back to the runway after an engine failure, I think that is the wrong thing to be teaching. back when I was a student and an instructor, we never taught to come back. Lose too much lift and altitude. much better off going straight ahead the safest place....street, field. Remember we are talking 152's not 737's.
Yea I teach 1000" AGL 180 OK, 500' AGL 90 OK, less than 500' straight ahead, make your decisions in advance so you don't waste time in a critical situation. Have a plan stick to it.
On thing to mention regarding a 180 after departure with a failed engine. Always turn into the wind if a crosswind exists. This will allow you to remain more aligned with the departure runway should you need to turn back. A tailwind behind you will put you further away and require more manuevering. Since many airports have multiple runways which intersect, sometimes a 180 back to the same runway isn't always necessary. In terms of banking, I recall a study done which showed that an approximate 45 degree bank was safe and provided a better return on altitude during the turn than did a shallower bank. The shallower bank took longer to get turned around and left you further from the runway.
Bad approaches tend to lead to bad landings, though not always. The best salvation to a bad approach is a go-around. Setting the example of attempting to salvage bad approaches is setting a bad example. Far better to teach a student to be conservative and go around...then teach the student to make a good approach.
This is a very good point. But what I am trying to see, is that the student has "control" of the airplane. The student has the skills to add a little power, maneuver the plane to where he wants it, and can finish with a nice landing. This is after doing slow flight, steep turns, stalls, touch and gos and go-arounds. This is the last confidence builder for both of us, to ensure that the student is flying the plane and not the plane flying the student.
This was my technique and may not be one for you.
Cessna 152, I demo the 180 at NIGHT and at 500AGL. Believe me, superstick I am NOT! It only takes practice, given the options of sitting on my thumb and riding it into the trees in the dark or turning it around, I'll make the field.
I agree, if it smells like pooh, guess what? It is. I'll let someone take me around ALL day until they get the approach correct. Only when they feel comfortable should they be allowed to land. Allowing anyone to continue a crappy approach to landing will only teach bad habits. Monkey see monkey do, or will 16000 hours cause one to forget this basic CFI tool. FOI.
The Cessna 172 is a good plane, the only thing that irks me about it is there are supposedly a million different techniques to land the thing. That's what I like about Piper & Cirrus.....there is ONE way to land, that's it. Fly by the numbers.
What I have found that works (I learned in a 172R, and my flight school is just retiring 172Rs now) is fly the approach by the numbers according to the POH. About twenty feet off the ground, start reducing power to idle and about ten feet off, begin your round out. As the bottom starts to sink, slowly raise the nose. Shouldn't have a problem.
I realize this is just a bit on the late end of things but I'll chime in with my two pennies.
To land a 172:
Whatever it takes to be on final (~600 AGL) at 65kias slowing to 61kias at 50' (roughly over the threshold) with full flaps as this is the "short field" technique. Once at the threshold, smoothly reduce power to idle. Notice the word "smoothly". Nothing in flying needs to be done knee-jerk...no yanking the throttle out so bad that the entire control comes out of the panel...just smoothly reduce it to idle. At this point, the nose starts to drop (it helps if you trim slightly nose up on final, but not necessary) and the natural reaction is to pull back...don't! FLY THE PLANE to ground effect, then you start the flare.
IMHO, the flare is a two part process. It's a "level off" and a "flare". In the "level off" phase, you are going from descent with the nose low, into ground effect and leveling off in ground effect. At this point, your view should be down to the far end of the runway so you can see yourself sinking. As you start to sink (which should be pretty soon if you're 61KIAS at 50' with full flaps and go to idle throttle), you just raise the nose enough to keep it in the same spot relative to the horizon. In other words, when you "level off" in ground effect, the nose is in a particular position...during the "flare" you simply keep it in that position by applying back pressure and letting the aft end of the aircraft (including the mains) sink onto the runway. Keep the back pressure in as the mains touch down until you can no longer keep the nose up. Let the nosewheel drop on its own as the airspeed deterioriates and the elevator loses any authority to keep the nose up.
Now, for the 180 to the runway...I'm going to abstain from that comment as the only "experience" I have with that is "simulated" at 3,000'. At that altitude, it just simply didn't work. I tend to teach small turns to avoid obvious obstacles below 600' such as a 20 degree turn to avoid a radio antenna and typically 600' on up to TPA I will let the student make a 90 degree turn. But then, I also teach upwind to 600', turn crosswind, downwind at 1000' (or TPA in which case, I adjust the upwind leg also except in the cases of noise sensitive areas), so that has a lot to do with it.
Good luck with the landings! It gets better and easier with practice.
-mini
The 180 back may work, but to many stall/spin accidents have shown more often than not, that it doesn't.
